RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Super Clod Buster Build-up Thread
Old 02-28-2008, 11:38 PM
  #2251
Lunchboxer
Lunchboxer's Avatar
Default RE: Super Clod Buster Build-up Thread
LOL, ballbearings from Hong Kong are here.. ha!
Old 02-28-2008, 11:43 PM
  #2252
Lunchboxer
Lunchboxer's Avatar
Installed some foam padding into the battery holder... now the battery is snug when in installed!
Just some small LB touch.. ha!
ID:	891286   Click image for larger version
Old 02-28-2008, 11:46 PM
  #2253
Lunchboxer
Lunchboxer's Avatar
Standard LB issue truck servo, S3305 metal gear... it will be installed in the stock location.. so it will be driving both front and rear steering...
Running the FM RX, instead of another 2.4GHz... so I can run the TXT (2.4GHz) and Clod at the SAME TIME... that's the goal.. ha!
Old 02-28-2008, 11:51 PM
  #2254
Lunchboxer
Lunchboxer's Avatar
Both axles are completed..
The pic is of the rear axle.. dial in some toe-in there for some stability... !!
Just waiting for one more piece of aftermarket item tomorrow.. then the Clod can be completed!! (well, I need to figure out what shocks to use... [:@])
Old 02-29-2008, 01:09 AM
  #2255
mindwreck
mindwreck's Avatar
e-maxx or associated shocks seem to work best.. the stock ones were good too if you wanted insane body roll.
Old 02-29-2008, 09:43 AM
  #2256
Lunchboxer
Lunchboxer's Avatar
I got some spare Tamiya buggy shocks / TXT shocks.. so I might run them in the mean time...
Old 02-29-2008, 09:45 AM
  #2257
broncojd
broncojd's Avatar
ORIGINAL: Lunchboxer
just buy another 2.4ghz radio! c'mon, we all know you've got it like that. ha!
Old 02-29-2008, 09:54 AM
  #2258
Lunchboxer
Lunchboxer's Avatar
I do have another 2.4GHz... ha.. but it is dual stick style... I doubt my fiance or friend would know how to drive that... ha!
Old 02-29-2008, 10:17 AM
  #2259
Longhair
Must...
Stay...
Away...
Before...
The...
Need...
For...
A...
Clod...
Old 02-29-2008, 10:33 AM
  #2260
Lunchboxer
Lunchboxer's Avatar
Longhair, Clod is a legend.. everyone needs one! For real!!
Old 02-29-2008, 11:23 AM
  #2261
secretsg
secretsg's Avatar
Did you find an ESC already LB? HK sellers have the TEU-103BK for $39.
Old 02-29-2008, 11:26 AM
  #2262
Lunchboxer
Lunchboxer's Avatar
E-Savage Speed GT ESC for some dual pack power.....
  #2263
Longhair
I bet you say that about all the kits
I will have to look at the instructions and put it on the back burner.
Old 02-29-2008, 11:27 AM
  #2264
Lunchboxer
Lunchboxer's Avatar
You can just look at the build thread.. show you everything... hee hee...
Nah, I would never say something like a TLT is a "legend".. (not yet!)
Clod has been around for 20+ yrs.. that's a legend there! As the first monster truck!!
ORIGINAL: Longhair
Old 02-29-2008, 12:15 PM
  #2265
cornel4web
cornel4web's Avatar
I just choose a tamiya product......TEU-103BK - For Twin Motor...just because I will stick with silver can's in my CLOD...
Old 02-29-2008, 12:18 PM
  #2266
Lunchboxer
Lunchboxer's Avatar
I will be running the silvercans too! Just w/ more voltage.....
Old 02-29-2008, 12:45 PM
  #2267
broncojd
broncojd's Avatar
wha?! LB, i could of SWORN i heard you touting the greatness of the novak super duty previously. what happened?
Old 02-29-2008, 12:55 PM
  #2268
Lunchboxer
Lunchboxer's Avatar
SuperDuty XR is in my TXT!
Just want to give another ESC a try!
Not to mention that it is cheaper by a good $50! ha!
Old 02-29-2008, 05:52 PM
  #2269
GTRice
Um, LB, I was wondering, what will the rc4wd axle tube brace do to the truck? Make it better?
Old 02-29-2008, 06:06 PM
  #2270
Lunchboxer
Lunchboxer's Avatar
Spread the load better so you won't snap the axle-Cs....
Old 02-29-2008, 06:23 PM
  #2271
Longhair
Mustn't...
Look...
How are you going to mount dual batteries?
Into...
The...
Light..............
Old 02-29-2008, 06:29 PM
  #2272
Lunchboxer
Lunchboxer's Avatar
I will make it up as it goes.. probably mount it inside of the chassis so from the outside it looks stock.. just one battery wire.. but I will use 2 straps inside to hold the 2nd battery.. hee hee..
Stock looking Clod -> not so stock...
Old 02-29-2008, 09:08 PM
  #2273
GTRice
I see, but I probably won't be needing them on my Clod then.
Old 02-29-2008, 09:14 PM
  #2274
Lunchboxer
Lunchboxer's Avatar
Always good to over-build your Clod.. hee hee..
But correct, unless you are mounting your 4-links to the axle-C.. or you still have the brace between the axle-C and the tranny case (the stock setup)...
I don't really know how yours is setup right now..
Old 02-29-2008, 09:17 PM
  #2275
Lunchboxer
Lunchboxer's Avatar
Stock Clod chassis... and w/ ESP aluminum brace!
Still stock setup, but just beefed up... hee hee.. that's my goal, remember!?
ID:	891941   Click image for larger version
