HBX, Who else owns one??
#4528
RE: HBX, Who else owns one??
I've recently entered into the R/C fun with the purchase of an HBX for my son off of ebay. After now having it a couple weeks and being satisfied with it I decided to also get one for myself (should be here wed) . I was wondering what type of battery upgrade is suggested and supply source? At this point being new into this sport I don't plan any big mod's, but a better battery would be nice. Thanks....
#4529
ORIGINAL: jleeper
The truck usually comes with a 6-cell, 7.2v NiCd "stick" battery pack of 1800mAh capacity (or thereabouts). There are two battery technologies that are better than that - NiMH packs (which are very similar but have higher capacities and better power output), and Lipos (totally different, needing more specialised chargers and voltage sensing ESC or circuits etc, but way more powerful).
Based on your question, I would suggest buying a 7.2v NiMH stick pack with a capacity of at least 3000mAh, and preferably something like 4500mAh. The former would cost (in the UK) something like Β£15, and the latter something like Β£28. Make sure it is a stick pack, and not "side-by-side". Be aware that you need a charger capable of charging NiMHs (i.e. not just NiCds, like the little one that probably came with the truck) which would be Β£15+
[You could buy a 7-cell, 8.4v version of the above, but if you are looking for minimum work be aware that they don't really fit in the battery slot and may burn up your motor/ESC more rapidly.]
I would not particularly suggest buying Venom as a brand.
#4530
MI
ORIGINAL: jleeper
Along with a better battery you may want to consider buying a good charger, if you don't already have one. I found that the long charge times is a sure way to turn you off to RC'ing. The Onyx series are fairly good chargers at a good price, but there are other brands to consider. Even though you didn't buy your car from a local hobby shop (LHS) you may still want to consider checking one out to at least get a charger.
Also, batteries are much cheaper on line, especially in the larger mah's. Larger mah's = longer run times. If you're in a hurry, Radio Shack also carries a decent 3300 mah for around $30 that will give you reasonable run time. As mentioned above, you'll probably want to stick with nimh batteries as a beginner.
#4531
Thanks for the suggestions!! So, would these batteries work ok in this auction? I'll also check into a better charger too...
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
#4532
MI
ORIGINAL: jleeper
#4533
ORIGINAL: jleeper
I often use Vapextech 7,2volt 3700mAh and Vapextech 8,4volt 3700mAh. They are good batteries for a low cost, and you will find them on Ebay...
#4534
hummm, i did it again, wife not happy
I was hapy with the buggy & with the success i had with brushless i was planing to make the bonzer brushless too... simple? yes... well no.
some how i ended up with a Traxxas revo platinum 3.3, humm i gess the bonzer has to wait again lol.
#4535
ORIGINAL: phmaximus
some how i ended up with a Traxxas revo platinum 3.3...
Is it going to be brushless too?
#4536
ORIGINAL: rallytorget
I have bought some of these battery and they were marked with 3800mah but they werenΒ΄t better than maybe 1500mah battery. So I suggest you donΒ΄t buy them!
ORIGINAL: jleeper
Vapextech.co.uk
#4537
CA
Can someone help me since this is a Haiboxing thread?
http://www.rcuniverse.com/forum/m_9002562/tm.htm
#4538
ORIGINAL: JMobile24
I have a Haiboxing Bonzer and I am looking for the part circled.
Its the part that you can connect the shocks to.
I looked all over for parts but can't find them.....
http://goldstarstockists.net/live/ca...cf4e40905380d2
#4539
ORIGINAL: bluefisherking
Ha ha Good job!
ORIGINAL: phmaximus
yeah i dont know? i think its $80 odd bucks just to get a motor mount/gearset. so may when the motor wears out i will shurly do it
#4540
My new HBX arrived today so tomorrow me and my son can trash around together... I did find one thing, that not all Bonzer trucks are equal, and what you get in one box is not the same as what you get in another.... I bought my trucks from different ebay sellers and even though they both say HBX Bonzer on the box, they came with different documentation, different spare parts and of course different paint and tires. Mine is the Cross Tiger and his is the Very Hot Fire. Originally I figured it was just a paint and tire change difference, but the Cross Tiger had much better documentation/manual but fewer(different) spare parts...FWIW..
I'll add a photo later after tomorrow's play day.
#4541
Well, today my son got to experience what happens when you run your truck full throttle straight on into a curb. I'm actually surprised it wasn't hurt worse and at least it was still drivable afterwards. He took out the front bumper and the plastic piece behind it sustained a crack. Afterwards we headed to a grass area where there were no curbs and told him he could take my truck for a spin and I'll drive his....well he was walking with the antenna pointed down and guess what....snap. Oh, well.... I have a little fixing to do now, not really all bad and hope to have them back in shape this weekend for more rippin'
#4542
Well Good news... I am gonna get back into Bonzering again....
Bonzilla is Ready just have to charge the Camera Bats and pray the suspension don't fall off again...
#4544
Hi guys,
I am a bit of a traditionalist.. (please donβt hate me for it) Was wanting to update the stock motor and was wanting people opinions on the follow ones.
team Associated Stockstar 27T 24 deg. Motor
Max. RPM - 33,200
Max. Torque - 145N/mm
Max. Power - 127.0W
Max. Efficiency - 70%
http://67.199.85.166/main/productdet...ory=5051.xxxxx
Tamiya Super Stock BZ 23T (off-Road) 53930
Max. RPM β 26,500
Max. Torque β 49mN.m
http://www.tamiyausa.com/product/ite...oduct-id=53930
Tamiya Dirt Tuned 27T 53929
Max. RPM β 17,000
Max. Torque β 37.24mN.m
http://www.tamiyausa.com/product/ite...oduct-id=53929
Thanks James
Max. RPM - 33,200
Max. Power - 127.0W
Max. RPM β 26,500
Max. RPM β 17,000
Thanks James
#4545
Hi James,
The only one of those motors that I tried prior to going brushless was the Tamiya dirt tuned. Like a few others in this thread, I found that it worked quite well, but had a fairly short life - it got hot and quite soon the magic smoke was lost.
The other two have impressive torque figures, but would seem to me (guessing) to be too fast to run with a 19T pinion. As such you could find them geared too high, with no easy way of fixing that. (Although depending on the screw holes in the motor, you might be able to use a 16/17T pinion by picking odd motor mount hole positions).
I certainly don't hate anyone for being traditional :-) , but I am curious nevertheless to ask why you wouldn't want a brushless motor? Is it for waterproofing?
#4546
prontozuk I have tried all those motors myself and none of them lasted more than 6 minutes using 19t pinion. At the moment I use a Mtroniks Vision 600 motor that seems ok but drains battery really fast. I would agree with most on here that if you want to stay with brushed the best motor to use is the Graupner Speed 600 Race 7.2v and it requires no modification to chasis to fit.
Sunny
Sunny
#4547
Yeah it is water thing and also a money thing... If I decide to upgrade to brushless then I have to upgrade radio gear as I have the bonzer with the radio and ESC together. At the moment I have to replace the spider gear in the rear diff as they chewed themselves out as well. So at the same time I might as well update the bearings... If I do all of it I might as well almost buy a new truck... $100 for 9T brushless ezrun, second hand controller and receiver $20 to $50 and bearings and spider gears $30 and also need new pinion as the one I have is sort pressed on the motor.
Thanks James
Thanks James
#4548
ORIGINAL: prontozuk
... I have the bonzer with the radio and ESC together...
#4549
I thought the Team Associated Stockstar would have been OK considering it is a 27T. I understand that the stock ESC can really only take down to a 23T...
#4550
ORIGINAL: prontozuk
