HBX, Who else owns one??
#1976
RE: HBX, Who else owns one??
Nice looking Bonzer Renato
I love those Rims!!!!
Some nice 2-wheel driving... but hitting your Dad's feet... not good lol
The Roll over looked nasty...
Looks like a Good area to run the Bonzer, you should get your Dad into racing them lol...
#1978
Hi V.R.M, you have only got your wheels on half wrong or half right The best thing to do about your wheel nuts coming loose is to buy Nyloc nuts and some washers
#1979
Yeah,I am too lazy to change it.I might have to refer some old photos of my truck to get it right again though[:@].Are you sure that the nyloc washers and nuts will work cause I have to check with my lhs if they have that or will any hardware store do?
#1981
Hi V.R.M, any 4mm Nyloc nuts and washers will do, we have a supplier of metal working machines, nuts and bolts and any other thing to do with the metal working industry down the road from us and we order whatever we need from them, real handy
#1982
AB, CANADA
does blue anodized aluminum show scratches and scuffs more than standard silver anodized aluminum? I just received my blue alloy parts and I'm having second thoughts lol
#1983
Hi syncronized77, YES!!!!!!! blue shows more scratches than the silver and also with silver you can buff it back up with a Scotch Brite pad. I have all blue on my touring car which has about 5mm clearance and it shows every off the track adventure that I have had, and I've had a few
#1984
i jsut got my hop ups for my V3 today
blue aluminium swing arms (4 set) and a tamiya dirt tuned
still need....new shocks (better ones like threaded oil ones) i have a broken shock on my V3 atm and i'm not sure how long it'll last.
but we also have some new 7 cell 4500mah battery's on the way , this is gonna be the beshed rc car ever
shaun
shaun
#1985
ORIGINAL: AVIV123
HI
THANK FOR THE HELP SO FAR
CAN YOU TELL HOW TO PUT THIS GPM ALLOY MOTOR MOUNT
ON MY BONZER
THANK THANK YOU
HI
ON MY BONZER
THANK THANK YOU
Uphil
#1986
ORIGINAL: Uphil
I've just got one of these idential to yours.... and i'm wondering where it will fit..... it looks too small...am currently striping my chasis down for a good clean and replace with some hop-ups.
ORIGINAL: AVIV123
HI
ON MY BONZER
THANK THANK YOU
HI
ON MY BONZER
THANK THANK YOU
#1987
See where the Heat sink mounts??
It Mounts on the Side of the Chassis and the theory is, as the Motor heats up, the Heat is transfered to the Motor mount Screws.. this Motor mount, cools the screws and the Chassis around the gears...
#1988
wow talk about decoration!!!
that motor mount looks like it does nothing at all!!!
how could all that heat go through the screws [:'(]
but nice bonzer BTW
i wish i had the $$ to get the knuckes and drive shaft too[8D]
shaun
but nice bonzer BTW
shaun
#1989
Thnx Magnat......was about the only place left that it could go....and as shaun has so kindly pointed out it's mainly just a bit of bling !
Uphil
Uphil
#1991
i have a bonzer v3 and i wonder if i can put Alu Tower on (i want 90 mm shocks) i have put a photo on and u can see i have only 1 screw hole the other side doesnt has one can i drill on in (and how to do that)or can u use the front side (where stock shocks are screw in) Sorry for my bad english and n00b questions.
#1992
And anothet Question
TLP Expro II Deluxe Lightweight Intellicharger with Discharger (110v / 220v)
This charger has the capability to charge all types of batteries, from 110mah through 3000mah. Advanced MOSFET pulse charge technology ensures a more optimal charge. It also has a built-in intelligent fast discharge function. Smart features include slow charge, fast charge with auto cut-off from fast-charge to trickle charge. A digitized peak detector helps determine when the maximum charge is obtained for superior battery performance and maximum number of rounds per charge. Built in fuse and cooling fan for extended durability and high performance. Strong enough to even charge a car battery. Includes a connector for charging small, stick, large and custom batteries. Charges batteries of ALL shapes and sizes from for any kind of AEG. Super light weight body means lower shipping costs for you! Capable of charging Ni-MH or Ni-CAD batteries. If you intend to charge 12v 10 cell batteries, then opt for the TLP TL-15.
Input: AC 110V 50/60Hz
Output: 4.8V-9.6V
80 Watts
Can this chargers charge battery like 8,4 4500 mah
cuz when i read it said only up to 3000 mah
But in features i read charging 3000 NH NH MH Batterij at up to 5.5a
Output: 4.8V-9.6V
80 Watts
#1993
yeah i want 90mm's too
but i think i'll make my own shock tower and bolt it onto the stock one.
good tip...crash into a road sign and knick the aluminium from it...say that it was dammaged anyway
i have 2 road signs and it is great aluminium!!
shaun
shaun
#1996
Yeremy that charger has a 3000mah limit so no it wont charge a 4200mah Batt
Output: 4.8V-9.6V
80 Watts
Output: 4.8V-9.6V
80 Watts
#1997
ORIGINAL: magnat
I mean, you can charge 4500mah battery with Bonzer stock charger, it just takes half a day , so why would this charger be worse in that sense.
Another reason might be the discharge function. May be the heat dispassion becomes a problem if discharging over 3000mah battery, but still I would say it is capable of CHARGING 4500mah though. But can't be sure, manufacturers make strange things sometimes to maximize their profit...
#1998
Hi yeremy123, try a search through the RC Universe site for a charger, some say through 3000mah some say through 3300mah for TLP Expro 11 chargers, they don't actually say up to 3000 or 3300, through means beyond. They also say "Strong enough to even charge a car battery" "80 watts output" and also a "cooling fan". Do some internet searches and get some feed back. The charging capabilities of chargers are limited by input / output, time, volts and amps, and the Expro has the ability (on paper) to charge some descent size packs. Sometimes you are better off buying a charger that is capable of charging all the known batteries on the market at the time Lipos, nicads etc.
