fastlane's Rising Storm Thread
Hi all! I just ordered a Tamiya Rising Storm from Rcmart and I have a question, what tools do I need to build this thing and what else do I need to complete the build(this is my FIRST build!)
thanx
fastlane
thanx
fastlane
CA
RE: Rising storm build prep
Phillips screwdriver (various sizes)
pliers
small needle nose pliers
paint for body
x acto knife
Im assuming you already have a transmitter, reciever, and servo(s), right? Those are the basic tools I use, but sometimes you'll need others for certian applications. I might be forgetting something though.
pliers
paint for body
x acto knife
CA
Only large kits come with TL, because the smaller ones wont need it. That is Tamiya wise, anyway, I don't think any other brands include TL.
i found a good hobby knife and fine grit sandpaper will help clear away any burrs on the kit parts. it's not a race, take it one step at a time. it will give you a better understanding of your vehicle, and will help you troubleshoot later on down the road.
Banned
My Feedback: (7)
TX
go to the lhs and get thread lock and some ca, cost youa bout 6 bucks, and its good to know that you arent going to lose any screws, cause hardware will end up costing more than some frekin thread lock will. josh
MN
ORIGINAL: fastlane500
Thanks, and I do have the TX, RX, and servo(s). Also, does any1 have any building tips?
CT
I just finished my first build and i skipped the very first step by accident..O-rings on the shocks..big no-no, oil went everywhere
so take your time and read directions thoroughly
My Feedback: (34)
ORIGINAL: jkrustchinsky
ORIGINAL: paintstikker
No, unless you want to glue the tires, but IMO you wouldnt need to glue the tires stock, but it would be good to anyway.
And -Brian, where in ct are you from? I'm in griswold.
ORIGINAL: -Brian
Yeah just a bog standard 12v car battery, it will last for quite a while - mine has lasted about 20 recharges and still going strong
AZ
There's a gadget out there that used for those small portable refrigerators that are used in the car, camping, etc.
It plugs into the wall and provides a 12v-6amp output, with a cigarette lighter plug, or for those PC freaks, an "accessory outlet". I got mine at Target for $20 a couple years ago. I think they're all the same, but they're sold under Igloo and Rubbermaid brands, and probably others too. Pick up a plug from an auto parts store or Radio Shack, and you're all set.
AZ
Uhhh, why? Mine's been working great for two years. It runs an Intellipeak Digital, which only came with a 7amp PS to begin with. I don't charge at over 5amps anyway.
