im having pede motor swap probs can anybody help me out .
hi, i swapped out my titan, first i put in a cheapo fireball and i noticed that the back wheels were dragging unless i gave it power it didnt roll freely when i had it on the ground and pushed it by hand or do well when i would let off on the throttle" if i had it off the ground just rolling the back tires it was ok "...so i put the titan back in and it was fine , then i tried an orion motor and same problems..can anybody tell me what this is ?? thank you much..
CT
RE: im having pede motor swap probs can anybody help me out .
Sounds like a simple case of high motor inertia. when you let off the throttle in an electric R/C, the motor's magnetic field does induce some braking function in the driveline. from what I've seen, the Titans have a relatively low braking effect, where as other, lower turn motors will have a greater effect when it comes to that. the only other thing i can think of is checking gearing when you install the new motor. make sure it's not too tight.
