RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Electric truck stuttering
Old 10-25-2007, 12:04 PM
Default Electric truck stuttering
Hey guys I am having a problem and am not sure whats causing it.
Truck: Team Losi XXX-T MF1
ESC: LRP v7.1
Controller/receiver: Sanwa MX-3
Motor: 19t komodo dragon
Here is what happens. If you accelerate and go up to full speed right before full speed or at full speed it will stutter. Like the throttle goes from off to on extremely fast maybe 3-4 times. It sounds like a rev limiter in a real car. It doesnt do it all the time and it only does it for a second or 2 before it clears up.
Normal? Bad ESC? Any info would be great. Thanks
Old 10-25-2007, 12:18 PM
Slo-V Flyer's Avatar
Default RE: Electric truck stuttering
Here's one possibility. Sounds like your battery could be dropping in voltage under acceleration enough to where the radio may be cutting in and out causing the stutter. Though this usually happens to high power brushless motor system. What battery are you using? It's unlikely though with a 19t motor that the battery would struggle like this. Is it possible for you to try another ESC or battery, that way you can eliminate one or the other?
Old 10-25-2007, 03:28 PM
it is a Venom 7.2v 5000mAh nimh battery. I will try another battery since I have heard venom isnt to good.
Old 10-25-2007, 03:53 PM
And the power connector (battery <-> ESC)? If that is improper, could have the same effect.
Old 10-25-2007, 05:18 PM
My MM5700 setup started doing that, I might try a BEC
Old 10-25-2007, 06:56 PM
ORIGINAL: Access
its a deans connector if thats what u mean.
Old 10-25-2007, 08:46 PM
RC_Basher20's Avatar
maybe need a new connection and i also have the Venom 7.2v 5000mAh nimh battery, i love it and mine also stutters i think its the connection dues to bent powerpoles
Old 10-25-2007, 09:27 PM
calvino's Avatar
if you don't have a good connecton, the car will studder, that simple[8D]
Old 10-26-2007, 05:29 AM
rcluke's Avatar
could be sticky brushes
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
