novak on LRP
allow me to re-phrase my answer...
yes, it WILL work.
as long as both your motor and esc are sensored, they will work fine together. Novak and LRP both make only sensored bl stuff, so you are ok to go.
yes, it WILL work.
i will be running the motor on a sensored esc but the person im buying it from ran it on a mamba max and it didnt work too well. do u think its damaged?
The Mamba Max is a sensorless ESC, so it's not unusual that it did not run the sensored motor too well. That's sort of a hit-or-miss thing. I bet the motor is fine.
