RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
XL, L motor choices
Old 01-12-2008, 07:58 PM
BackFilp 360
BackFilp 360's Avatar
Default XL, L motor choices
Im building a hyper 7 using a mm esc, 2 5000 2s but dont know a motor for my application . The beast shouldnt weight more than 12 lbs. Are there better brands out there iwas think maybe a 8xl or a 7xl . Any suggestions will be helpful.
Old 01-12-2008, 11:59 PM
Slo-V Flyer
Slo-V Flyer's Avatar
Default RE: XL, L motor choices
8XL or 9XL for sure. The L's have about 66% of the torque that XL's have.
The 9 XL should run cooler and be able to use high voltage for some good speeds with out overrevving.
Old 01-13-2008, 08:25 AM
83gt
there are plenty of better brands out there dependent on what you want to pay. Neu, Lehner, Aveox, Plettenburg. If you're on a budget, an 8XL will do nicely on the cheap.
dirt101
yeah either an 8xl or 9xl. I personally would go with an 8xl, but yes the 9xl will run cooler.
Old 01-13-2008, 11:45 AM
Slo-V Flyer
Yes, you mentioned brands, so to clear things up, I was talking about Feigao XL.
Old 01-13-2008, 01:04 PM
BackFilp 360
Thanks slo, How much kv does the 8xl have
Old 01-13-2008, 07:39 PM
dirt101
2084k/v
Old 01-13-2008, 07:44 PM
BackFilp 360
Cool do you have it in your revo? Cause i was going to use 4s, 5s should be carzy fast !! Is there a cheaper place to buy it than rc-monster Cause they want 90 $ for it
Old 01-14-2008, 12:50 AM
sloppyG
I run the 9xl in my e-revo on 4s (stock nitro gear ratio/pinion/spur)
it's every bit the equal of the 3.3 nitro
zero issues of heat, even after running through a 5000 mah pack (for as long as 2 tanks of nitro)
Old 01-14-2008, 02:28 AM
Slo-V Flyer
ORIGINAL: BackFilp 360
offshoreelectrics.com has the XL motors (though they are not the black heatsink ones, just plain purple) for $20 less than rc-monster, that's where I got mine from. They also have S and L motors as well as other brands. Good shipping too, $10 and about 4-5 days to your door...
Old 01-14-2008, 07:28 PM
BackFilp 360
do i need the heat shink ? And is the 7xl too hot for the hyper??
Old 01-14-2008, 07:56 PM
Slo-V Flyer
Since you said the whole thing is about 10-12 lbs, it might be especially with high voltage.
Old 01-14-2008, 11:02 PM
BackFilp 360
Slo, you run a 3s in your revo how does it run? So i might go 4s to see hoe it run. My friend has a x-1 cr jammin buggy with 4s. Wow does that thing move I should be getting my buggy this week Will the 888xl take the power of the 5s?
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
