stub axle spins??
RE: stub axle spins??
Yep those are the bandit axle stubs like said they go "through the axle to hold in place the hex that your wheel sets on"
I thought the bandit was only rear wheel drive though is it for the back wheels?? do the wheels spin but not connected to the dogbones for power?
See if the part you are referring too is on here. If so what is the number?
http://www.traxxas.com/PDF-Library/2408_rear.pdf
If it's not there, then look through these links and find the part number...it will be here if it is a traxxas bandit VXL
http://www.traxxas.com/products/elec...ndit_views.htm
Good Luck
Good Luck
