Good single battery electric 4wd truck?
OH
I like the E-revo, but I would really prefer a 1/10 truck that is single battery. I am not overly interested in super speed, but I do not want a rock crawler. I would also like to be able to find parts. I thought about converting my DF-02, but that buggy overheats a 27-turn geared all the way down with regular sized tires (I use high capacity batteries). If the DF-02 were capable of more gearing combos, I would use it. If I get one, I am planning to use for some fast runs up dirt, grass, gravel hills, and general bashing. Any ideas?
RE: Good single battery electric 4wd truck?
I changed my df02 into a truck and really enjoy it. I have an e revo, but the single batt and weight of the df02 makes it more fun and less likely to break. I am running a vxl motor and a mm esc w/stock gearing - no heat issues and very torquey (sp). I also have a tamiya twin detonator that is fun and tough but the suspension is too bouncy, it has two motors but seems to run for a long time. CEN is suppose to be coming out w/ a 4wd truck based on one of their nitros - looks good and should be durable if it is the same as the nitro version. There are also bonzer trucks on ebay that are knockoffs of tamiyas, so you can get parts when they break. I have two of them too, but like the df02 best.
OH
Like I said, I am running 15 or 16 tooth (whatever is the lowest it can accept) and a 27 turn motor but I am still overheating 180+ on longer runs. I do not want to go brushless in the df-02. How do you keep it cool? What is the stock spur, what spurs are available, what size hex hubs are on the DF-02, and how do I use that POS motor mount to mesh properly with a bigger spur?
OH
Could my motor be getting hot because of the 24 degree stock timing? Do you think a 19-turn with 0 timing might run cooler?
OH
Well let's say hypothetically, that I strapped my modified 19 turn to the DF-02 and it hit 240 degrees F endbell during a run geared 16/70. What kind of aftermarket brushed motors are others running in the DF-02? There is no binding in my drivetrain.
My Feedback: (7)
ORIGINAL: guver
If you will Consider 2 motors then maybe the tamiya Twin det, ect.
