What C rating should i be looking for in a lipo battery?
Was looking at a few lipos and some said 20c 25c and others said 12c which one is best
RE: What C rating should i be looking for in a lipo battery?
there is no "best"
the C rating is relative to how many amps you can draw from your pack.
so for exampel my rustler VXL motor can draw 65A continuous (any more and it'll fry).
to get the maximum continous amp draw you devide the capacity (in mah) by 1000, then multiply the number by the C rating to give you the amp draw.
eg, 4000mah pack = 4000 \ 1000 x 12c = 48 Amps
so if you have a current draw on average of say 60+ amps then you're gonna want somthing like this...
8000mah pack = 8000 \ 1000 x 12c = 96A
4000mah pack = 4000 \ 1000 x 25c = 100.
so it's all about capacity to amp draw.
if you have a low capacity pack then you'll be chasing a high C rating,
if you want a big pack (8k or more) then you can get away with a lower C rating in smaller cars (rustler, slash etc)
and if you have a big car (revo, E-maxx or E-8ight) then a high C rating AND capacity is gonna be needed.
hope this makes sence
shaun
shaun
CA
hey i got a question.
i looking at a 8000 mah with 80 amps contious and 120 burst.
the mamba max says it can handle 100 continous.
How much can the mamba max take in burst?
CA
and another ?
if i have 2 batterys with the same c rating and rum parralel does that double the c rating.
My Feedback: (325)
It seems many people get this backwards. The battery needs/can be sized with a higher current capability than the motor (can pull)
The motor pulls current, the battery doesn't push current.
My Feedback: (325)
ORIGINAL: Snaut Rocket
and another ?
and another ?
My Feedback: (10)
so I am now more confused than when I started reading this thread.
talk to me like I am stupid because I am just not getting it -
is there a minimum c rating that would be considered adequate for our uses - yes or no?
were the nimh batteries in the 10c range? yes or no?
is there a max battery size per configuration in regards to c rating and MAH(which would vary depending on your parts) - yes or no?
MAXIMUM battery size doesn't matter to the extent of the motor pulls the current - yes or no?
not trying to be a smart *****, I want to understand
My Feedback: (325)
The rating must be combined with the capacity of the pack since "C" stands for capacity (see Shaunmichael's response)
The capacity multiplied by the "c" number gives the total so you need a combo that equals your max current of your specific set-up. I suppose that's a no?
NI batts can range widely 2C to 30 C probably. I guess that's a yes.
My Feedback: (325)
Maybe I can make it simpler:
Find out max and average current of set-up with desire voltage.
Select largest battery that will fit with desired voltage making sure it has at least the current capability by multiplying the capacity by the actual number that is before "c"
It's a multiplication problem 20C , 10C ect. The c is the capacity and your product needs to be larger than your current of your vehicle.
Maybe I made it harder ,lol.?
CA
ORIGINAL: guver
Yes.
and another ?
and another ?
Read this thread (there is also a page 1) and I think you will understand. [link]http://www.rcuniverse.com/forum/m_7898973/mpage_2/tm.htm[/link]
I bet the Orion SHO 5300 nimh cells get 35-40C. They are extremely powerful and get great runtime. Only thing is that they are around $120 for a assembled battery or $85 for 6 loose cells!!!
2 batteries in parallel means twice the capacity, yes. It doesn't change the C rating per se. But with two batteries, you can safely supply twice the current than one of that same size normally could.
ie. a 5000mAH, 20C battery supplies 100A. 2x 5000mAH, 20C batteries in parallel would be a 10000mAH, 20C battery, it would supply 200A.
Most NIMH are good for 10C and some of the high-end ones 15C or so.
The "C" thing is explained well enough above. "C" = capacity. "20C" means 20 times capacity.
And if you want to get into the fine details you actually lose a little bit of C rating when you put two batteries in parallel. Especially if the batteries were treated differently in the past, or are at different parts of their life cycle. With two batteries in parallel, there is no gaurantee the internal resistance is 100% equal, so depending on the difference you may only be able to safely draw 1.9x or 1.8x the current or so.
CA
So the C rating wont increase, just teh amps. got it. About getting cells balanced how about 4 cell lipo balancer?
CA
ORIGINAL: Access
AB, CANADA
wow, there is a lot of info flying around.
The "c rating" is a function of the battery but not the capacity. The mah is the capacity (C), the "c rating" is just a way for the manufacturers to tell you how quickly the battery can "give up" it's charge. That's why it's important to get well matched cells. A battery made up of 3 cells with different "c ratings" would discharge at different rates and therefore would become unbalanced.
So the C of a battery is the capacity in mah (milliamp hour), the c rating (factor by which you can increase the output) is different and let's not confuse them. A 5000mah 20c battery can output 5000ma in 1 hour but can increase the discharge rate by a factor of 20. So the amps the battery can output is equal to the C x c rating / 1000. So a 5000mah 20c battery can put out 5000 x 20 / 1000 = 100amps. If you're wondering why we divide by 1000 it's to convert milliamps into amps.
When you put two batteries in parallel with the same c rating you double the C (capacity) but not the c rating. So 2 2S batteries with a capacity of 5000mah and a c rating of 20 can produce 10,000mah at 20c which is 200amps.
It was correct when it was stated that the batteries don't push, the motor pulls. The motor has an amp rating, that is how much the motor can pull. You need both an ESC and a battery that can meet it's needs. So a motor that can pull 100amps needs an ESC capable of handling 100amps of continuous current and a battery capable of outputing 100amps continuous. If your battery can put out 200amps that's fine but it will only be asked for 100amps.
a C rating is just a number for the formula.
it's just that, a number, you cant increase it or decrease it, it's like part of an algerbraic equasion.
pretty simple when you understand.
ORIGINAL: Druss
Where do these myths come from. You can't change the laws of physics. Basic electronics theory; series = one current path (only) and voltages add; parallel = multiple current paths but voltages are the same.
ORIGINAL: Druss
If you want to design it safely, you have to look at both RMS currents and peak currents. Not continuous currents. Those are for DC only. You do the peak current like a DC system (straight resistance) and RMS current based on the manufacturer ratings and such. But if you neglect peak current, you do something like run your vehicle into a wall at full throttle by accident and if the wheels happen to stop spinning before you let up on the throttle, the ESC will go poof and die. Thermal shutdown probably won't save it at that point.
My Feedback: (33)
Boy am I confused now . I always thought it was like Druss stated . But what Access states makes sense also .
CA
ORIGINAL: Dawman
Okay let me post this example to try to clear it up.
Say you have a Neu 1506/1Y motor 0.0030 ohm resistance; a mamba max ESC, 0.0003 ohm resistance, about 2 feet worth of 12awg copper wire (0.003 ohm). Total resistance 0.0063 ohms.
The battery is an 11.1V (3s), 4000mAH battery with a 5-to-15-second "burst" C rating 40C. Meaning it's gauranteed to stay above 9V for 5 seconds even if you pull 160A out of it. Approx. internal resistance for a voltage drop ~2V @160A = 2 / 160 = 0.0125 ohm
So the peak current we need to account for would be 11.1V / (0.0125 + 0.0063) = 590A.
Now look at something like the VXL ESC:
http://www3.towerhobbies.com/cgi-bin...&I=LXSDB8&P=ML
Peak current stated by manufacturer 320A, meaning it shouldn't be used for this setup. Even though the on-resistance is double that of the mamba max, that alone isn't going to drop that much.
It's fine for use with the blue "VXL" motor (which is going to saturate at a couple hundred amps anyways) but not with something like the Neu 1506.
The only electronics / physics formula I used above is Ohm's law, E = IR or sometimes also stated V = RI; (voltage) = (resistance) * (current).
One more thing, take a look at the new Losi ESC as another example
From the horizon site, Operating current 100A continuos, 540A peak, and on-resistance 0.0004 only slightly higher than the mamba max. 540A would be closer to the 590A needed and hence probably good enough (at some point even the Neu motor will saturate).
AB, CANADA
sorry, access is right in that the current flow through the circuit is the same but also consider that the c rating and capacity together determine the available continuous current and max current. The issue here then is that one cell may have to work harder, and therefore get hotter, than the other cells in order to provide the same current as the system. This is the reason that usually the one cell puffs and not all together. The weakest link theory.
