disable mm bec.
CA
disable mm bec.
I was going to get a mm and run it on 4s and i guess i need to know, how to disable the bec unit on there.
Can some one take me through the steps.
My Feedback: (10)
RE: disable mm bec.
remove the center wire from the esc to rx connection. If you push the tiny pin and pull it out you would be able to reinsert it later if you wanted.
I find it amusing that 4s voids the warranty, yet there is an lvc setting for 4s built-in to the castle defaults
