My new E-revo, so disappointed, why this happend!!??
Today I got a E-revo for x-mas, and Im so pissed right now, I was all exited wating for today, and boomm white smoke comming for the battery boxes.
So.... I got 7-cellElite 5000mah for it, charged them, everything normal, run in for the first time in training mode and very gently as suggested in the manual to break-in the titans, everything ok, I waited everything to cool off, and charged them again. I ran it for the second time, same as the first one, in training mode and very gently, ran about 10-15 minutes, and I had to go do something else, so I bring it in, and when I was going to shut the esc off, the car started to glitch and inmediatly white smoke started to come from the baterry boxes to the "ventilation holes" in the battery boxes and a strong smell of melted plastic, so I rapidly disconnected both batteries and waited thing to cool off, to check and this is what I found ( look pic ), everything other than that looks normal, but now my "spanking brand new $400 truck" doesnt work anymore.. Im so pissed!![:@][:@] I didnt do anything wrong!! I was being super carefull with everything!! IM SO frustated. What can I do?? anyone have any idea?? are my batterys still usable?
NE
RE: My new E-revo, so disappointed, why this happend!!??
Looks like they overheated or overcharged. that has happened to me once. Do use a peak charger?
I think just the plastic wrapping melted. The batt's should still be usable.
yes, I use a Super Brain 977, that have been using 2 years now, its not the charger. I was doing very light driving....
NE
I have no idea how, but did you check all the wires to see if their hot or touching each other? If the wires connecting to the motor is hot the motor short-circuited. Was the ESC hot? Does it even get any ventilation at all??? From my experience the ESC gets hot no matter how soft you go.
Moderator
If you charged them with that charger under the proper settings and ran lightly, that's really strange - especially since it happened to both batteries.
Use another set of batteries just to make sure the ESC and motors are still working fine.
That should tell you who you need to get in touch with, because if those batteries are new I'd make a small fuss over them.
ORIGINAL: sheograth
I tried to connect the batterys to the charger, it it only reconizes 1, at 8.48v, the other one, it didnt even say 1v
AB, CANADA
Are you checking the temps as you run? You really need to do that...
Also, when you run in training mode does it just reduce the voltage through the esc in order to reduce speed? maybe that's causing a lot of heat.
VT
did you get the packs "upgraded" cuz if you got um with out that feature, you probally put too much thru the spot welds just because of the quality of the batts, and the draw of 2 motors, they're going to discharge a lot even if you're driving slow, and spot welds are good for like 15A max, those cells are probally good to 40-45A so you probally heated them up and maybe shorted a pack...
the lug
the lug
ORIGINAL: rclugnut10
the lug
the lug
ORIGINAL: So Cal Nitro Basher
rclugnut is right, if you did not get them "upgraded" thats mostlikely your problem.
the lug
the lug
Now, that I have looked closer at the batteries I would have to agree with rclugnut10 and So Cal Nitro Basher.
CA
This is what happens when you dont upgrade AND you didnt choose SXS configeration. I really dont see a con of SXS. You can use an equalizer, you can check the voltage of every cell, and there is less resistence.
I charge them at 5 amp, because thats the maximun the SB 977 can charge at.
But c'mon!!! I was driving really slow and gentle on the thottle, and for Druss yes I do check the temps, the first run, after 25 min of the same slow driving the batterys where at 108f°, the esc during the run was similar to the batteries but at the end of the run where at 140f°. Cant belive this "quality batteries" fail even at this speeds...
Up-Date: I managed to connect the battery that still work and a 6 cell battery from a losi spin-start, just to try if it still works, and at first it didnt, just a solid red light, after messing with the set up button, it now appears to work as normal, so I think its safe to say the evx-2 is safe, and the titans too..
VT
ORIGINAL: Racing T
and for first charge its better that you run them at like 500mha...
the lug
they dont have a 7cell dischager/equlizer anyway, lol, at least not that I know of.
Call up CBP and gripe to them about it. It's pretty obviously their screw up if you ask me. The truck can't short your batteries. And if it did the ESC would have fried before the packs did.
yeah, I didn't get the up-grade, but this is suppose to be a sport level truck not a super racer or something that need super cells, the strange thing is that I know of people that run cheap no-name batteries without problems, and this suppose-to-be quality cells fails.. I mean.. is very frustrating, I was hopping to use it in my vacations, I guess I would not...[:@]
I will try to contact Mike from cheap battery packs, to see what he have to say.
ORIGINAL: FairTax4me
Tekin makes one for 8 cell packs. But the cut off is 0.5v and non-adjustable, so for nimh packs its probably no good.
yeah youre right, about the ESC cooking if it would be the cause.
CA
ORIGINAL: Racing T
ORIGINAL: Racing T
IL
you really need to reconfigure them to side by side packs. i had two trinity 4600 reference packs that i ran in my emaxx and then two 4200 powerizer packs in SxS configuration. The 4600 that were in a shotgun pack ran almost 150* the powerizers ran between 115* and 125* the normal operating temp is between 100* and 140*. so reconfigure your packs and there shouldn't be a problem.
Why in the heck did you charge them at 5 amps? You will shorten the life of your packs dramaticlly by doing that.
