Cleaning Slash with garden hose ok?
My Slash got so muddy and dirty today that I use the garden hose and spray it clean. is that ok since the electronics are waterproof?
RE: Cleaning Slash with garden hose ok?
If you are willing to properly take care of the motor and bearings then its perfectly fine. But I would buy some WD-40 and spray down the motor afterwards.
BC, CANADA
ORIGINAL: samguan
AZ
ORIGINAL: munro300
NO
ORIGINAL: samguan
Yes you can use the hose, but you don't want to SPRAY it. The manual is pretty specific that you can let the water from a hose run over it to clean it, but DONT put your thumb/finger over the end to increase the pressure, as that could force water into the bearings and past seals in the ESC, servo, and radio box.
BC, CANADA
ORIGINAL: Stampede Killer
why
ORIGINAL: munro300
NO
ORIGINAL: samguan
I clean all my rc's with a garden house, the nitro ones, I remove the engine and all the electronics, the e-revo, that is the closest to the slash as water proof goes, I remove the motors, unscrew the ESC, and put it in a ziploc bag, remove tires and I spray it down, inmediatly I spray it with wd40.
CA
Taking your electronics off is a quick thing that doesnt cost anything; while ruining your esc and receiver cost alot of money.
