B3 Shocks
IA
B3 Shocks
I've recently noticed the major flaw I believe to be holding my buggy back, and that is suspension. It's an RC10 B3 with the original shocks and springs. They get the job done decent, but I think a nice new aluminum set would do a much better job. Any suggestions on shocks and springs for my buggy?
Here is my current set up (Don't mind the prices I just copy pasted off my FB)
Associated B3 Roller- $30
Reedy Stockstar 27 Turn- $45
Dynamite Tazer 12 Turn ESC- $60
Airtronics MX-3S Radio System- $99
Futaba S3305 Metal Gear Servo- $38
B3 Bearing Kit- $20
RPM Front A-Arms- $8
New Thrust Bearings/Spring- $4
Fast Eddy Stainless Steel Screw Kit- $20
Lunsford "Fat Boy" Titanium Motor Screws- $8
Factory Team Titanium Turnbuckles- $20
RPM Turnbuckle Ends- $5
Body/Paint- $25
Venom 3000 MaH 6 Cell Battery- $27
Deans Plug conversion- $2
No Solder Golden Leads- $2
Bad Horsie Shock Covers- Free
Tires are Proline Step pin rear and sum generic ribbed ones on the front.
B3 Bearing Kit- $20
Body/Paint- $25
IA
RE: B3 Shocks
Well unfortunately money doesn't grow on tree's where I live. I have two older peak racing brand 2400's that are putting out a lot better voltage, however I needed another decent battery and that is what my lhs carries. So again, anyone have any suggestions for shocks?
IA
RE: B3 Shocks
What do you think?
[link=http://cgi.ebay.com/4Pcs-ALU-F-R-SHOCK-Damper-Suspension-Fits-RC10-B4_W0QQitemZ110350229961QQcmdZViewItemQQptZRadio_C ontrol_Vehicles]Shock #1[/link]
[link=http://cgi.ebay.com/4Pcs-ALU-F-R-SHOCK-Damper-Suspension-Fits-RC10-B4_W0QQitemZ110307374932QQcmdZViewItemQQptZRadio_C ontrol_Vehicles]Shock #2[/link]
IA
RE: B3 Shocks
Decided on these shocks, the FT ones are 50 bucks a pair, so that was a no go. These ones cost me 44 shipped. My buddy has truck style ones identical to the ones I just ordered on his Rustler and they seem to work very well. Also got a graphite shock tower to replace the composite one that has had the top mounts ground off (previous owner must have had some excessive roll over's).
CT
RE: B3 Shocks
What about the stock shocks do you think was holding your car back? The standard AE shocks are really nice when correctly built and maintained.
Big drops in shock performance are caused by dirty shock oil, old o-ring seals (they absorb oil after awhile and swell, causing friction), the shafts lose their polish and create friction, the piston can wear out on the outside diameter, and the anodizing can wear off the inside of the shock body.
The shock covers can hamper performance as well.
Front:
35wt oil
#1 piston
green springs
middle on the tower, outside on the arm
Rear:
30wt oil
#2 pistons
silver springs
Middle on the tower, inside on the arm.
Front:
35wt oil
#1 piston
green springs
Rear:
30wt oil
#2 pistons
silver springs
