traxxas slash
traxxas slash
hey im kinda new 2 this whole forum thing but i was wondering if any 1 new how i could make my traxxas slash not so tippy cuz i flip it all the time... and does any one know what the best gearing is for top speed??? thanks
RE: traxxas slash
i think changing the shock oil to a heavier oil helps, now if i can only get my shock cap to open..[:@], also check out the new chassis that came out, supposed to stop the rolling pretty well (on road at least)
AB, CANADA
RE: traxxas slash
ORIGINAL: rc master22
I know that everyone always wants to upgrade to get better performance but the slash is one RC that I plan on leaving stock. Sure I'll tweak it and maybe upgrade certain parts with RPM as they break but it's fun BECAUSE it drives the way it does.
AB, CANADA
RE: traxxas slash
The gearing will depend on which motor you use. If you have a stock one I can't help you, upgraded to VXL before I even ran it the first time.
CA
RE: traxxas slash
My best advice to the gearing question is buy all the pinion and spur gears you can find, from 15t to 28t and see which one you like the best.
RE: traxxas slash
why did you even buy a slash? it sounds like you should of bought a buggy or stadium truck.... just remember that taller gears = more top end. shorter gears = more bottom end, which is what you want for off-roading. buy a variety pack from tower and experiment.
http://www3.towerhobbies.com/cgi-bin...&I=LXEX34&P=ML
RE: traxxas slash
As far as the tipping problem; here is my set up. I never flip wile running slicks on pavement.
shock a-arm position: all four all the way to the outside holes.
Shock fluid: 50wt on all four
springs: stiffest my local hobby shop had
preload: none
ON, CANADA
RE: traxxas slash
hey guys wondering if u guys can help have a slash with 6900 kv mamba and esc! had the on off swich rip off the esc is there a way i can fix it with out useing the on off sitch ie allways on with batt pluged in?
TX
RE: traxxas slash
Yah just join the ends of the two wires at the end where the switch used to be together and it will always be on with your battery plugged in.
