Gearing help
Lol ok. So ive been doing this for almost 3 years and i still suck at it. So im getting this motor
http://www3.towerhobbies.com/cgi-bin...?&I=LXTRX3&P=0
Im running a Team AE B4 and I WILL be racing. what is a good grearing right now i think its at 24-81 and thats with a 14x2 brushed motor
Banned
VT
CA
Neither do many people. I read that once, but go by my own rules of gearing. Couple questions.....
What brushless esc will you be using with the Eraser 13.5T? I would actually reccomend a Novak mtoor, as this is what most popel run. LRP speedo, novak motor.
Your going to be running in the super stock class because of the 13.5T motor right?
There is NO PERFECT gearing for ANYTHING. My suggestion is to buy ALL pinions from 20-32, and get a bunch of spur gears and see what you like best. You might like alot of accelration, might like more top speed. So just get a bunch of pinions and spurs and experiment!
Im useing the Lrp Brushless A.I esc that matches it. Right now im running 24-81 i would like alitte bit more speed and ill be happy. But im worried about the motor heat than the esc i can touch the esc for a long time. but the motor for a good 5 sec befor it hurts.
IA
There's really no replacement for an infrared thermometer when you're picking gearing. Doing touch-tests to make sure you're at a safe temperature is unreliable and inaccurate. Drop the $20 for a decent thermometer and you'll never have to question your gearing again.
CA
ORIGINAL: For_The_Win
You have a 14X2 mtoor but you want more speed? The 13.5 is equivalent to a 19t brushed motor, so you will see less performance. How often was the comm cut and brushes changes and bearing oileD? That makes a HUGE differnece in performance.
I forgot to get a temp gun at the Lhs. But its not hot enough me to take my finger off so i say its around 150 160. And the the motor. Its my crap one that i used for fun. My real motor is my 12x2 orion revolution. But as for gearing should i drop the pinion to 21 instead of 24 would that give me better speed?
CA
CA
If you would gear lower, it wouldnt get as hot. Other reasons could be not cutting the communtator, repalcing brushes, etc. Did you do any of those? What is your esc rated to in brushed turns?
