question on 2200kv castle momba
The esc has one positve and one negative. Am I supposed to solder two red wires off the positive and two black wires on negative or how should I do this? Any help on how two connect two packs to the momba monster would be great! Thanks!
Moderator
RE: question on 2200kv castle momba
You need to wire the batteries in series if you're trying to add their voltages together.
Wire the positive of the ESC to the positive on one of the batteries. Then wire the negative to the negative on the OTHER battery. Now connect the remaining leads on the batteries together.
You'll want to achieve that with connectors of course.
My Feedback: (7)
to elaborate a bit more, go from the (+) on the esc, to the (+) on your 1st batt, go from the (-) on the 1st batt to the (+) on the 2nd batt, now connect the (-) on the 2nd battery back to the (-) on the esc for a series connection. for parrellel just group your (+) and (-) together.
