XXXT ball studs breaking
I have a Losi XXXT and keep beaking the ball studs(4-40 x 1/4) (losi part # A-6006). These are the ones that go into the rear hubs. Ive found Titanium ball studs but dont know which ones are the correct replacement ones. Can anyone help?
Also what about putting Aluminum rear hubs on? Where do i find these as Ive only found ones for the MF2.
Thanks for the help.
CA
RE: XXXT ball studs breaking
DO NOT put the aluminum rear hubs on. Those came with the CR and alot of people break those, and if you do, $40 for a set. Plus you would need quick change hubs. I would highly reccomend Lunsford ball studs. Put those on and you should never have a problem again.
Thanks Chris. I couldnt figure out which ones i needed but I talked to Losi and they sold me some titanium ones from them. Hopefully they work.
