mamba monster 2200kv
im getting a mamba monster 2200kv motor and esc combo, do i need to get a new spur gear, cause i have the stock 47 tooth one now? and would the 18 tooth pinion gear that comes with the kit work pretty good, any recommendations would be helpful. thanks.
going to be putting it in a savage x, and do you know if you can have two batteries hooked to the esc or just one?
RE: mamba 2200kv or 2650kv
yo uare going to want the 2200. the 2200kv motor is 40x75 while the 2650kv motor is only 40x68. also, you can't run 6s lipo on the 2650. yes, you can run 2 batteries at once. there are two ways you can do it.
for example:
2 3s 5000mah lipos in series will be like running 1 6s 5000mah lipo.
2 3s 5000mah lipos in parellel will be like running 1 3s 10,000mah lipo.
2 6s 2200mah lipos in parellel will be like running 1 4400mah 6s lipo.
if using 2s or 3s lipos, get a series adaptor. if using 4-6s lipos, get a parellel adaptor.
hope this helps
for example:
hope this helps
well i plan to run maybe a 5s lipo, any websites you have that i can look at to get this parallel adaptor for the mamba monster esc?
ORIGINAL: sharkattack99
Don't be so lazy ..... http://www3.towerhobbies.com/cgi-bin...?&I=LXNKY8&P=7
RE: mamba monster 2200kv
so what spur gear and pinion gear would you recommend for all out SPEED!!!!, and what combo would you recommend for off roading?
ORIGINAL: mycarisaser
You will need a new mod 1 pinion gear. the one that comes with the system is a mod .8 . It will not mesh right
