RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Four Cell Packs in Parallel Connection Charging??
Old 10-11-2009, 11:24 AM
mnrcaerobat
My Feedback: (197)
Default Four Cell Packs in Parallel Connection Charging??
Should I charge two four cell packs that I run parallel together? Do I just put a balancer on each pack?
The packs are both 4s 2650mah. Does this allow me to charge them at 5.3mah?
Old 10-11-2009, 11:44 AM
t9dragon
Default RE: Four Cell Packs in Parallel Connection Charging??
No, you need to charge them seperately. You can damage the cells charging them in parallel.
Old 10-11-2009, 12:03 PM
guver
My Feedback: (325)
If they are lipo or li-ion packs then they can be charged in parallel (same as you use them)
Old 10-11-2009, 01:23 PM
rclugnut10
rclugnut10's Avatar
i wouldn't if they were discharged to the different levels unless your balancing them both, with separate blancers at the same time to ensure equal voltages, then again with a 3rd inline charge balancer to ensure all voltages are equal while charging
the lug
Old 10-11-2009, 02:07 PM
mnrcaerobat
My Feedback: (197)
Both are lipos and used in a truggy in parallel.
At what rate would I charge them?
Old 10-11-2009, 02:10 PM
guver
My Feedback: (325)
You can charge them at double speed (current) compared to just one pack. If you use 2.5 amps then for two of them you can use 5 amps.
Old 10-12-2009, 12:20 AM
gelbschnee
gelbschnee's Avatar
you can safely charge at 5 amps (just under 1C for both packs in parallel)
