RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Where to get a tire balancer
Old 10-12-2009, 02:06 PM
Blazing_angel_
Default Where to get a tire balancer
i need to balance a tire or two. can anyone tell me where to get the thing on which you place the tire? thnaks
Old 10-12-2009, 02:34 PM
t9dragon
Default RE: Where to get a tire balancer
What RC are you running the tires on?
Old 10-12-2009, 02:35 PM
Blazing_angel_
A stampede xl-5 waterproof
Old 10-12-2009, 02:48 PM
t9dragon
I haven't ever balanced tires for my son's Stampede. What is wrong with your tires that cause them to need to be balanced?
Old 10-12-2009, 03:00 PM
Blazing_angel_
im fairly useless. i tried to drill a hole in the tire for water running, but i believe i also punctured the foam. i let the tires ballon up, and i noticed that the tires only have a slight vibration (the rears). One of my front tires needs new foam though. do you think that this slight vibration could cause problems in the long run? thanks
Old 10-12-2009, 03:03 PM
Brainanator
Brainanator's Avatar
I just use the front hub of my slash, probably not as perfect as something designed to balance, but it spins freely enough for me. I just try to make sure I block up the truck level, and balance away.
Old 10-12-2009, 03:13 PM
t9dragon
The vibration could be caused by a bad bearing.
Old 10-12-2009, 03:14 PM
Blazing_angel_
ORIGINAL: Brainanator
i tried to do the exact same thing with my pede. it worked fairly well, now i know where to put the "balancing material", but what should it be?
Old 10-12-2009, 03:32 PM
Brainanator
I use the sticky tack that's used to hang posters....Seems to be working well for 5 runs or so. There is a special clay for balancing, called balancing clay, but I'm sure it's twice as expensive as it should be. Many people just use none-hardening model clay. Bubble gum might work too....lol
Old 10-12-2009, 03:36 PM
Access
If you are brave enough to venture into the aircraft part of most hobby shops, you can typically get a prop balancer which can double as a tire balancer. Just don't let the people around you know what you are buying it for...
Old 10-12-2009, 09:57 PM
Blazing_angel_
ORIGINAL: t9dragon
i highly doubt it because it started after the fateful drilling
Old 10-13-2009, 09:50 AM
khudzik
Dynamite makes a real nice tire balancer, part number DYN2620, it's made for buggies and truggies and uses 17mm hex, so I'm not sure if you could make it work on smaller wheels. Instead of clay though you could use DYN2621 balancing tape, it works good.
