mamba is good...no?
#53
i think i will go with a mamba 1/8th scale 2650 motor and use a 6s li-po or a 5700 on 2 2s li-po or do what i wanted to do use a mamba 9000 on 3s li-po becouse i will never reach full rpm(yes i will put heatsink and very good fan
#57
ORIGINAL: vpower
i just want to know which is best for drag racing (i think the 5700 can handle s s2 li-po correct me if im wrong)
#58
My Feedback: (20)
ORIGINAL: srt10
2s
that's what it's made for
ORIGINAL: vpower
#59
If you are serious about drag racing would be better of with a different car like gms or team walbern pro stock,funny car or dragster chassis. These will get in to the speeds you are looking for. Look in the drag racing forum for tim smith's speed records on 2s. this will give you an idea of what it takes to go that fast.
#60
My Feedback: (20)
ORIGINAL: overrev
#61
ORIGINAL: vpower
ok are you all listening too me?javascript:void(AddText('[:@]','_image/s6.gif'))
i said i wont use it offroad untill i prove im the fastest at a drag race here in miami Florida,s tropical park ill be running a rhino 1550 mah 3s li-po once i prove im the fastest i will buy a 2s li-po and gear it down for off road (yes i will put a fan on the thing)[&:]
#62
ill just go with the mm 2650 on two 3s li-po. the reason i will use the e-firestorm is becouse im running against a traxxas rustler(and i want to be fair)
#63
ORIGINAL: Wild YFZ 450
Do you honestly think a firestorm on a 9000kv motor with a 3s lipo is going to even be fast. Theres no way that it can even keep up with a real dragster. I will just laugh at the fact you want to run a 3s 1550mah lipo with a 9000kv motor. You know the fastest car right now is in the 160's (MPH).
ORIGINAL: vpower
#66
I'm not trying to be mean but your battery is to small for the 9000. I would try it on 3s but with a bigger and better battery. I have seen some people run the 7700 on 4s so I think you could run the 9000 on 3s. The people who run them are just running them less than 30 seconds and not worried about burning them up.
#68
ORIGINAL: overrev
#69
ORIGINAL: Yosh70
Why? Did you decide to go turbo or supercharger?[img][/img]
ORIGINAL: vpower
can i get an moderator to delete this?
#72
Like I said it not made for offroad but can be used if geared very low on 2s but you have to watch the temps. The motor I run most of the time is my medusa 4800 more power and runs way cooler than my castle motors 5700 and 9000.
#73
ORIGINAL: vpower
where can i get that for elec?
ORIGINAL: Yosh70
ORIGINAL: vpower
Your buddys wont stand a chance after you tell them what you installed on your Firestorm.
#75
OH
I believe 5700kv on 3s should be faster than 9000kv on 2s if you gear it up, plus when you're tired of a straight line its pretty fun on 2s. The MMP will let you tame it even more if needed.
If you're SERIOUS about speed I would look at some of the bigger motors on the Hobby King website.
Mamba Max Pro plus a High C rating 4s lipo plus this:
http://www.hobbycity.com/hobbycity/s...hless_Inrunner
I bet it would go a legit 100mph if done properly.
