RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Lee's Tamiya Dual Hunter build thread
Old 03-10-2010, 01:03 PM
lee172
lee172's Avatar
Default Lee's Tamiya Dual Hunter build thread
Following the 'one in-one out' rule, this replace's the Tundra..
Old 03-10-2010, 01:04 PM
Lunchboxer
Lunchboxer's Avatar
Default RE: Lee's Tamiya Dual Hunter build thread
You need some high voltage ESC and power this bad boy up with dual packs!!
Old 03-10-2010, 01:14 PM
lee172
lee172's Avatar
a little unusual as it uses twin motors instead of a driveshaft to achieve 4WD..
twin motor needs special ESC...
ID:	1395316   Click image for larger version
Old 03-10-2010, 01:22 PM
Casper06
Casper06's Avatar
You sold the Tundra?
I always wanted to see one of these kits built. Looking forward to the build Lee!
Old 03-10-2010, 01:31 PM
lee172
lee172's Avatar
it is for sale but it hasnt left me yet!
my main problem with the Tundra was its constant rolling over.. it tackled some serious gradients as long as you drove at it square on, as soon as the camber changed, over it went! [:@]
Old 03-10-2010, 01:45 PM
Eman77
Eman77's Avatar
Sweet build thread! I'm looking forward to seeing all the hopups you'll put on this one. At least, I assume you will put hopups on it. I mean, you're Lee, right?
Old 03-10-2010, 03:18 PM
cummins driver
My Feedback: (31)
cummins driver's Avatar
Nice, Ill be watching this thread[8D]
I was thinking about buying one of these for a basher/hill climber and doing some modifications. I like dual motors with a tranny and driveshaft better than this setup, but thats just personal preference because im sure it works fine. I ended up buying another stampede so that i can modify the one I have now to run on 2 batteries(14.4v) with a brushed electrc E-Savage motor.
If you want quite a bit of power, running 2 batteries along with 2 HPI E-Savage motors, or traxxas titans would make it fly. Lots of power, and I think the gearboxes are pretty strong in that truck too, although I have heard the driveshafts can have problem.
Are you going to be running it stock, or build it up? What kind of running are you going to be doing with it?
Eric
Old 03-12-2010, 01:16 AM
grater
grater's Avatar
Can't wait to see this build up Lee, was going to buy one as my first hobby grade R/C a few years back. Very interested to see how it comes out.
Old 03-12-2010, 08:54 AM
KENDALL96
ohh man ill be watching this..
i have a Blackfoot Extreme and a Mighty Bull..
both based on the same chassis except its 2WD.
Old 03-12-2010, 02:28 PM
rymansl2
rymansl2's Avatar
Nice choice in a replacement! I have the 2wd version of this and I absolutely love it. Pretty much indestructable. I just put a Traxxas EVX-2 esc on it (dual batteries and dual motors) and it FLIES. I only have the one motor hooked up but I would highly suggest you upgrade the tamiya esc with something that can handle hotter motors and dual battery packs. The extra volts really make a difference
Old 03-13-2010, 08:00 AM
lee172
lee172's Avatar
hop ups for this are very limited, so this is all i have so far..
i plan on getting a Blackfoot Extreme body for it as it looks much better than the stock, although the colourscheme on the box reminds me of a TRF buggy!! [8D]
dont think i'll be putting monster power or any crazy motors in it yet, will see how it is on the silver cans first
Old 03-13-2010, 06:35 PM
lee172
lee172's Avatar
Tamiya TEU-103BK ESC.. [8D]
weirdly Tamiya decided to pre-build the gearboxes in these trucks.. Blackfoot Extreme is the same (only one gearbox though)..
two sizes of pinion are catered for..
a kit builder's worst nightmare... plastic bushings!! [:'(]
ID:	1397384   Click image for larger version
ID:	1397385   Click image for larger version
Old 03-13-2010, 06:42 PM
lee172
lee172's Avatar
i'm not worried though..
pretty huge diff! [X(]
looking better already! (not sure why they use two shafts and one tube for to hold the gears...) [&:]
identical gearboxes all built up..
ID:	1397387   Click image for larger version
ID:	1397388   Click image for larger version
ID:	1397389   Click image for larger version
Old 03-13-2010, 06:48 PM
lee172
lee172's Avatar
not a huge array of parts, but not too basic either..
suspensions shafts isntead of the tacky 'u shaped shaft'.. [8D]
all is fine till i need to secure the e-clip nearest the gearbox case.. there's so little room that needle nose pliers are no use at all.. [sm=angry.gif]
rear end almost complete, need to seek out the CVA oil dampers that came with the FF-01 that i never used...
ID:	1397392   Click image for larger version
ID:	1397393   Click image for larger version
ID:	1397394   Click image for larger version
Old 03-13-2010, 07:44 PM
grater
grater's Avatar
Looks great Lee, why would they prebuild the gearbox's? gearbox's are the funnest parts of R/C cars to build in my opinion....
Old 03-13-2010, 09:16 PM
Eman77
Eman77's Avatar
Lee, are all the bearings sizes the usual Tamiya 5x11x4 size?
Those e-clips can be maddening, can't they? [sm=drowning.gif]
Old 03-14-2010, 06:08 AM
lee172
lee172's Avatar
i honestly cant think why the gearboxes are pre-built, firstly its a kit so none of it should be built, secondly there are more basic kits out there that dont have a pre-built diff, so i cant understand Tamiya's reasoning behind it.. [&:]
them e-clips are bad enough when you have two edges to grip onto with pliers, i only have one, so i have to push the e-clip on.. [:@]
bearings are all 1150 size.
Old 03-14-2010, 07:43 PM
lee172
lee172's Avatar
front arms attached..
FF-01 shock instructions.. i left out part V3 and they work out perfect.. (these shocks were spare as i used TRF dampers on the FF-01)
used #200 weight oil (red)..
damper assembled, leaving them overnight to aerate..
ID:	1398333   Click image for larger version
ID:	1398334   Click image for larger version
ID:	1398335   Click image for larger version
Old 03-14-2010, 08:35 PM
Jeremy Z
Jeremy Z's Avatar
I'm sure it is because that is the assembly that n00bs screw up the most, with disastrous consequences, and Tamiya probably found it cheaper to remove that element of chance than to try to help these folks get it right.
Looking good Lee.
Old 03-14-2010, 08:51 PM
Lunchboxer
Lunchboxer's Avatar
WW-2 comes w/ the gearbox assembled too.. always have to take it apart first to put the ballbearings in... [:@]
Old 03-14-2010, 09:38 PM
lee172
lee172's Avatar
well.. it seems apart from the hop-ups i already have, the only others are aluminium ball connectors, aluminium servo stays and aluminium wheel nuts..
Old 03-14-2010, 11:59 PM
grater
grater's Avatar
ORIGINAL: Jeremy Z
Tamiya's manuals are really accurate and easy to understand though I suppose the odd person stuffs it up and for people who want to run it as soon as possible it decreases the build time.
Aluminium parts.....Will that be blue aluminium Lee?
Old 03-15-2010, 12:02 AM
JEC55
lee 172, where did your find the suspention shafts?
Old 03-15-2010, 05:41 AM
lee172
lee172's Avatar
not sure on the colour yet, i have stock brass ball connectors, blue aluminium ones, pink aluminium ones and silver aluminium ones in the parts bin!
here's where i got the suspension shafts from (dont worry about the TL-01 title, they fit a few different models)
http://www.rcmart.com/catalog/rc-tl0...01-p-8293.html
Old 03-15-2010, 09:01 AM
KENDALL96
Hey lee..
what shocks are you putting in?
im planning to put a 4inch shock setup on mine but i saw some people pop their dog bones and the steering arm hit the box (where the front diff should be)
i have a Mighty Bull btw
i have been looking at these forums and everything was custom  made
http://www.rcmt.biz/bd/forumdisplay.php?f=21
so any suggestion??
and nice build..
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
