Tamiya Nissan King Cab or Toyota Hilux parts??
I am looking for Tamiya Nissan King Cab or Toyota Hilux parts wheel hex hubs and the axles that go with them. Anybody know where I can get or how to make what I have work with a new style wheel hub with the pins instead of teeth. looked on ebay and nowhere to be found.
CT
the best place i found is ebay look for the toyota hilux parts. there are a couple of guys that sale parts for the trucks im looking for a new brushless motor & esc and servos to replace the og parts i found a body that fits for it i just got to get the parts
When buying parts off Ebay you need to be careful. Tamiya made a couple of different trucks that carried the Hilux name. I believe the parts you are referring to are the 12mm hex that sticks onto the splined shaft. I believe it was my King cab that I did this too but I could be wrong. The way I got around that was to drill a hole in the axle shaft then stick a pin through it similar to the way traxxas does things. You can then use normal 12mm hexes with the cross pins.
