RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
Cigarette lighter plug to wall outlet
Old 05-07-2010, 10:49 AM
Specialzed
Banned
Default Cigarette lighter plug to wall outlet
I bought a charger and the only output it has is a cigarette lighter plug like this:
Is there any adapter or power supply I can buy that will allow me to use this charger with a wall oulet?
Old 05-07-2010, 11:32 AM
rpg711
Default RE: Cigarette lighter plug to wall outlet
The only way to get the charger to work with a wall outlet is to get a DC power supply and by either opening up the power supply(if the cigarette lighter plug is attached to the PCB) or making a male-male banana connector cord(if it uses banana plugs). There is no sense in using an adapter with the cigarette lighter plug. If you don't feel like opening it up you can always cut the connector off and solder on banana connectors.
Old 05-07-2010, 02:57 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
also I believe radio shack sells a car plug outlet to AC power supply
Old 05-07-2010, 03:29 PM
mechanizeddeath
mechanizeddeath's Avatar
Not really sure why they'd use a lighter adapter, most people I know hook directly to the battery or use a 12v DC power supply.
There are small adapters that go from a wall outlet to a lighter socket, but they are intended for cell phone chargers and other low power devices, and won't supply nearly enough power for your charger.
I've seen larger ones at auto parts stores that might work, but you'd be better off cutting the lighter plug off and going the banana plug route with a 12v DC supply.
Old 05-07-2010, 03:42 PM
Brainanator
Brainanator's Avatar
the only one I've seen was rated to 2amps...which is surely insufficient for high powered battery charging.
I say, cut the wire, put male banana plugs on the wire going to the charger, female banana plugs on the cig adapter, and get a 12V power supply with female banana.
Old 05-08-2010, 09:21 AM
kahnen
kahnen's Avatar
When I got that charger, I went to walmart and bought this Black and Decker travel mate. Its got more than enough amps for that charger. I'm actually still using it with my Turnigy accucel-6 charger. If you can't find it in the store should be able to find a place on line to get one.(E-bay, amazon etc.)
http://www.amazon.com/dp/B003775G9S/?tag=amazonsite-20
Should be able to find it in the sporting goods/camping section.
