30c vs 40c vs 50c
ON, CANADA
30c vs 40c vs 50c
If i compared 3 lipos all 4s 5000mah but one 30c another 40c and 50c.
How much of a difference is there? Would the 40c and the 50c really be that much better.
Is it worth the extra like 40 bucks, just to get 50c rather than 40c?
VT
RE: 30c vs 40c vs 50c
it depends on what you're doing copetative racing then you'll want all you can get, light racing and bashing the 30c's should be just fine unless you're using a super high draw Bl system....
thelug
thelug
My Feedback: (325)
If the numbers are actual specs then the difference is of course what it is (30,40 and 50C)
It is kinda like asking what the difference between 30 , 40 and 50 mph is. It is of course 10 mph (or 10C)
It's up to the individual if it is worth the money. On the other hand if you are asking "will I notice or do I really need 50C" then as lug pointed out it depends on your application. If you discharge batts in 1-2 minutes then 50-60C is very important and 30C will not cut it. If you discharge batts in 30-60 minutes then you may never see a difference between 30 and 50 C.
