Stripping Spurs E-revo BL
My Feedback: (14)
PA
When I hit hard from a bad landing from a big jump I strip spurs gears. Not all the teeth just one section .I tighten the motor as much as possible but I think the problem is flex in the blue plate on the transmisson. Does anyone else have this problem? If so has anyone doubbled that plate?
VT
RE: Stripping Spurs E-revo BL
are you on power when you hit the ground, that could be your most likely issue, the differance between your motor speed and the wheel speed when it hits, this is incredibally stressful on drivetrains and can cause major dammage....
the lgu
the lgu
TX
Loosen your slipper a notch, that might help the transmission slip some with the wheels as they hit the ground, compared to the the motor pinion as it turns the spur gear full speed ahead.
