mamba max
well I haven't been able to go to the hobby shop latley and i was looking on ebay and found a mamba max 4600kv system and i like how i could get deffirent motors to use on the esc. and on 3s because the guy i run with has a Baja 5t with almost nothing stock. so is it as good as the mmp.
RE: mamba max
The MMP is the newer version to the Mamba Max. The Mamba Max is a great esc .
RE: mamba max
what gearing would work best </p> |
RE: mamba max
What are you using it in?
RE: mamba max
HPI E-firestorm 10ht
RE: mamba max
lost the bid :(. Just guna buy the 35a ezrun with a tycoon 4300kv on 3s with stock spur and 24t pinion for onroad and 21t for offroad :eek:
RE: mamba max
dont exspect the same ammount of power, adustibility or quality i have two operating mamba max's best esc's ive had a chance to own, 100amps cont. vs 35amps on a good day. you will find that your bl system runs too hot that you'll have to gear lower under 20t at the sacrifice of speed. the 5T will eat that 35amp alive without breaking a sweat,
RE: mamba max
This is a joke right?
How many questions have we answered and yet you still don't listen? Uuuuugh. |
RE: mamba max
Sorry TBJ i'll just get the 4600kv mamba max [:o]
RE: mamba max
It's a good choice...not the only choice.
We just don't want to see you fry that little 35a speed control your first time out, man. Nothing sucks more. The 4600 is great...but you may want to hold on a little bit and wait until Castle comes out with the 3600 motor if your truck is still running well as it sits. Get the MM and the 3600. That being said...Castle has a Clearance sale going on right now. $150 for an MM and a 4600 [X(] http://www.castlecreations.com/promo...clearance.html |
RE: mamba max
Also, transmission ratio seems to be 2.60:1, same as ThunderbirdJunkie's SC10.
If you wind up with the 4600 (which again, is a GREAT motor) start with an 18t pinion and the stock spur and check temperatures after 5 minutes of running. |
RE: mamba max
On tower they have it for 160 but take of 20 for that sale so its 140+10 for shiping and its 150 shiped instead of 174 shiped yay:D. I have a 19tpinion to use so double yay:D
RE: mamba max
19 should get you close, but you should really look into picking up one of the 6 packs of Robinson Racing pinions.
Is that the Mamba Max or Mamba Max Pro that's $160 on Tower? |
RE: mamba max
Nevermind, regular MM. Still sweet :D
RE: mamba max
Invest in a temp gauge, And keep the temps below 175f and its all good.
RE: mamba max
WOW $75 for the MM esc.. dammmmm I just fried mine 3 months ago and bought two HK ones.. (nothing wrong with them they just aren't the same). I told myself I'd not spend any more, but this is hard.... $75.. ughhh.. [&:]
EDIT: *DROOOL* forget the MM, just ordered the 1518 motor hehehe......my Summit will finally break parts. |
RE: mamba max
Slo-v flyer use this code to get 30% of it <font size="3">military30 :)</font>
RE: mamba max
ORIGINAL: yoyo5 Slo-v flyer use this code to get 30% of it <font size=''3''>military30 :)</font> |
RE: mamba max
Dont let a clown tell you a 35amp will work, it wont. My recent mamba max was 100cad to the door
RE: mamba max
Im now guna buy this motor http://www.hobbypartz.com/96m30-car-2848-4300.html mamba max esc http://www.castlecreations.com/products/mamba_max.html this battery http://www.hobbycity.com/hobbycity/s...idProduct=8579 this charger http://www.hobbycity.com/hobbycity/s...idProduct=7028 and this power supply http://www.hobbycity.com/hobbycity/s...dProduct=11758 with 19/86 for gearing TBJ thank's for telling me not to get that 35a esc because the motor pulls 100a so mamba max esc should work good ;)</p> |
RE: mamba max
i was the first one to tell you that it wouldnt work, and you need 3650 motor not 2848 that would be to small. i run a tacon 3650 (540 sized) 3200KV fastest motor ive ran on 3s
RE: mamba max
lol no you werent, tbj was in a different thread.
ORIGINAL: Redvanmafia i was the first one to tell you that it wouldnt work, and you need 3650 motor not 28**. i run a tacon 3650 3200KV fastest motor ive ran on 3s |
RE: mamba max
okay keep sucking, 1000 this month is the goal
RE: mamba max
ORIGINAL: yoyo5 Im now guna buy this motor http://www.hobbypartz.com/96m30-car-2848-4300.html mamba max esc http://www.castlecreations.com/products/mamba_max.html this battery http://www.hobbycity.com/hobbycity/s...idProduct=8579 this charger http://www.hobbycity.com/hobbycity/s...idProduct=7028 and this power supply http://www.hobbycity.com/hobbycity/s...dProduct=11758 with 19/86 for gearing TBJ thank's for telling me not to get that 35a esc because the motor pulls 100a so mamba max esc should work good ;)</p> The rest of the stuff is fine. You might want to make sure that lipo will fit in your truck, it is 145mm long, and from my experience, It won't fit in a typical 6-cell battery compartment due to being almost 1/4" too long (unless it's going into a Slash type compartment with the adjustable foam spacer for long/short batteries etc). |
RE: mamba max
ok, just keep thinking
http://roflcon.org/wp-content/upload...s-business.jpg ORIGINAL: Redvanmafia okay keep sucking, 1000 this month is the goal |
