Lexan Body Stitching
Here's what happens when your Slash 4x4 PErear stock tires explode on you and bust out your rear fender wells and does a hard roof landing. Then you go back with thin CA and medium CA ALL the tires again. 3S and higher gearing with stock rubber doesn't work out so well lol.
Then you go in and drill into the body and stitch it back together with zipties, CA, silicone, and heavy duty duct tape. Time for a new body? Idon't think so....lol http://i973.photobucket.com/albums/a...Image044-1.jpg http://i973.photobucket.com/albums/a...Image045-1.jpg http://i973.photobucket.com/albums/a...Image040-1.jpg http://i973.photobucket.com/albums/a...Image041-1.jpg http://i973.photobucket.com/albums/a...6/Image039.jpg Sure ain't the prettiest but she sure can handle her own! Only broken parts so far was one of the hinge screws on the rear backed out and broke off the side of the A arm. Replaced with RPM rears. Beyond that also broke the front splined steel output shaft...it completely broke in half but the aluminum drive shaft splines were all in tact and nothing else! |
RE: Lexan Body Stitching
Use some shoe goo over the tape to make it more secure :D
For racing who cares if it looks pretty as long as its functional |
Still looks like a body - why replace it?:D
<span style="color: #ff0000"><span style="font-size: medium">REDNECKREPAIRS</span></span> http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif
Gotta luv it. |
True that proud to be born and raised in Texas yeeehaw!
As someone else suggested, next time get yourself a tube of Shoo-Goo or Goop. It can be obtained in various departments at most walmart stores.
You'd be amazed at how strong the stuff is, and it sure makes for doing a neater and longer-lasting repair. Us racers have been using the stuff for years, reinforcing weak areas of bodies and places they want to crack, and it sure works better than any duct tape/CA/ziptie/silicone ever will. |
That will be my next purchase at Walmart....I need Shoe Goo anyway. My boots are coming apart at the bottom rubber sole!
working on my own body reinforcement project with shoe goo, zip ties, a CD, and one other special item....
Will let you guy know how it goes in my own thread when I come to a conclusion. I like the ziptie idea, I'm using it ;) adds tensile reinforcement to parts that have ripped apart too large for shoegoo alone. |
Yes sir....whatever works works! I'd even use some thin soldering wire if need be. Whatever you can get your hands on from weed whacker wire to fishing line. DO IT! Lol.
ORIGINAL: Brainanator I like the ziptie idea, I'm using it ;) adds tensile reinforcement to parts that have ripped apart too large for shoegoo alone. The other issue is that there are things we do ourselves in which we have to take the blame for the body failure, like the OP who chopped out his windshield. While a "racer's trick," to aid in airflow though the truck instead of getting trapped underneath it, is not a neccessity for bashing and fun running. There's also something that could have been said for doing it a bit neater, and rounding the corners (to relieve a "crack zone") instead of making them square. Then there's also the consideration of addressing breakage areas before they crack, as in putting a dab of goop or shoegoo on known stress areas before running the body, instead of waiting for it to start cracking to do anything about it. |
I put a lot of duct tape around the inside of my bodies. Partially to protect paint, also to support corners and such.
When I cut out a clear body shell I save all the trimming. When you get a crack you use the Lexan trimming as backing and use the Shoe Goo adhesive so you end up with a very strong repair no matter how big the crack is. Since the trimmings have different shapes and profiles you can usually come up with a backing peice that has a profile or curves that matches the cracked part of the body close-enough. I also use trimmings to re-enforce the holes for the body posts.
Next time try reinforcing it with Shoe Goo and fiberglass drywall tape WHEN THE BODY IS STILL NEW . It works GREAT and I have had bodies go a whole season without any major cracks .
ORIGINAL: JustinThyme I put a lot of duct tape around the inside of my bodies. Partially to protect paint, also to support corners and such. |
ORIGINAL: DARKWAV When I cut out a clear body shell I save all the trimming. When you get a crack you use the Lexan trimming as backing and use the Shoe Goo adhesive so you end up with a very strong repair no matter how big the crack is. Since the trimmings have different shapes and profiles you can usually come up with a backing peice that has a profile or curves that matches the cracked part of the body close-enough. I also use trimmings to re-enforce the holes for the body posts. |
