RCU Forums
-   RC Electric Off-Road Trucks, Buggies, Truggies and more (https://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/)
-   -   Traction Help (https://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/10111488-traction-help.html)
TQamazer 11-02-2010 03:54 PM
Traction Help
I run my slash on hard packed clay on race day. I have S1 compound tires by Traxxas.
Any other tips to get traction and get the truck to turn better?
LewAshby 11-02-2010 04:39 PM
RE: Traction Help
Add weight in the tires.
Justin B 11-02-2010 05:13 PM
RE: Traction Help
Do you have to run those tires? A better set of tires would help greatly.
ThunderbirdJunkie 11-02-2010 05:21 PM
RE: Traction Help
If this is a spec class and you MUST run the Slash tires, wipe them down in simple green.
morespeed 11-02-2010 05:41 PM
RE: Traction Help
ii have these tires and they work great, if you came find them. i got mine from tower hobbies. jconcepts goose bumps.
ThunderbirdJunkie 11-02-2010 05:47 PM
RE: Traction Help
Goosebumps won't work well where he's running.
dug44 11-02-2010 07:54 PM
RE: Traction Help
1 Attachment(s)
Loosen your slipper another quarter turn, take the foam in your battery compartment and slide it to the back. Your battery wires will not reach if they face the front, so keep the wires to the back just stick em through the hump pack hole on the battery strap. That will help you improve on the steering a little bit. Make sure you have the shock full of fluid, I use 60 in the rear and 50 in the front. I bought the integy spring kit and went with the black ones for the rear and left the front alone, just moving to the outside hole on the bottom. 1.5 degree negative camber in the rear and front. Check to see if your hobby shop carries the lead weights in a strip. I put 2 on each side of the chassis in the rear (each side of the esc), and 3 of them on the top of the tranny case. 1 on each side of the chassis in the front... If you are able to switch tires, I have the calibers in the rear and the goosebumps in the front. The track I run on is packed clay... Very slick on the sunny days. This is the best set-up I have found yet... As you can see, it is dry clay....
RobbieP 11-03-2010 09:01 AM
RE: Traction Help
ORIGINAL: TQamazer
Traction comes down to two things - tires and set-up.
If you can't change tires, the least you can do is clean them (between heats if neccessary) as dirty tires do not grip as well as clean tires do.
The other things is thatyou have to adjust your set-up, springs and shock oil changes, to make it do what you want it to relative to your driving style and personal preferences.
Otherwise, 2wd trucks are notorious for being "push mongers" and you can't just keep mashing the gas through the corners and expect them to turn well.
Slow down to go fast.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
