Stampede XL-5 Motor Worn Out?
Yesterday my friend pulled out his XL-5 Stampede along with me. He has not ran his a whole lot, compared to me, I've probably ran over 150 charges or so. And I noticed, his is WAY faster than mine. And WAY more torque. My guess is, that my motor has well reached the end of it's useful life? Is this most likely it? If it is, what is a good brushed motor? Or would the Power Up Program for the VXL system be a better choice? I will almost certainly not run LiPo if I get VXL.
RE: Stampede XL-5 Motor Worn Out?
Have you ever put comm drops in? How bout oil the shaft? Even though it is a sealed motor, it still requires maintenance.
http://www.rcuniverse.com/magazine/a...article_id=356 |
most likely the brushes in the motor are becoming corroded, making them not as efficient. vxl has virtually no maintenance, but there's the cost too. i would recommend just waiting until u have 25 bucks and going down to the hoby shop and picking up another titan 550.
I may try to go for VXL. I just use my Stampede on the week days to relax after homework. On the weekends, I pull out my Jato for intense action.
cool. check my youtube channel. here's the url:<span class="Apple-style-span" style="font-family: 'Segoe UI'; white-space: pre; ">http://www.youtube.com/user/TheHuntingTerminator?feature=mexp#p/u</span>
I like that background, original Stampede?
ha, no, but i'm glad u liked my channel. its actually a rustler that has stampede tires on it. watch this vid and it'll tell u about it: <span class="Apple-style-span" style="font-family: 'Segoe UI'; white-space: pre; ">http://www.youtube.com/user/TheHuntingTerminator?feature=mexp#p/u/7/OlvPLwGrvSo</span>
If i were you I would swap batteries with him to make sure you still have the same results. Its possible the batteries are getting weak. The motor is also a possibility, just might want to be sure before you throw parts at it.
Eric |
I kind of can't do that because mine is an older model when it still ran the Tamiya connector and his is a bit newer with the Traxxas connector. I think we could just pull the connector off of his charger and try it. But ya, my 2 1800mAh 7.2V 6 cell NiCad Venom batteries may be going to hit the end. Although my motor may be it, because my motor makes ALOT more noise than his. His is pretty quiet compared to mine. So, motor worn out?
it probably is. just save up 30 bucks or so and buy a cheap 7 cell, this will fix most of your problems. ever look at my youtube vids?
Well not only that, when neither of them are running, and we just roll them, my motor makes more noise when it is rolling than his does.
i'm sure ur motor is bad, but buying a 7 cell will make it perform like it did with a 6 since ur motor's bad. after awile just buy another motor. its what i'd do
Well, most likely it is both your motor and your batteries. Nicads don't last very long, especially if they are as old as they sound (1800 mah). :D They lose their punch and capacity and just don't have that performance any more when old. Try his motor/battery (you could simply swap your ESC and battery for his so you don't have to mess with plugs.
Also, I would HIGHLY recommend you swap to new Traxxas or Deans high current connectors. Tamiya connectors SUCKKKKK bad and will hog a lot of current due to their resistance. That is one more source of problem in your truck. They can and will often melt due to the intense heat build up from the heat at the connectors. I guess you've not used it in such bad situations to cause them to go bad, but it's a good idea to upgrade ESC and battery connectors yesterday. :D |
ORIGINAL: cooldriver385 I kind of can't do that because mine is an older model when it still ran the Tamiya connector and his is a bit newer with the Traxxas connector. I think we could just pull the connector off of his charger and try it. But ya, my 2 1800mAh 7.2V 6 cell NiCad Venom batteries may be going to hit the end. Although my motor may be it, because my motor makes ALOT more noise than his. His is pretty quiet compared to mine. So, motor worn out? Let my nephew try it in his pede once when he was here it didn't even move his pede after the chargers claimed it was done... BTW those batteries were charged 4 times only from new... Heres a simple test take the motor out of the pede. Grab one of the good batteries and plug the motor wires straight to the battery. If it spins the motor still works. And like slow-V said swap to traxxas connectors they cost $3 on ebay |
