Lipo balancing?
Hey everyone i have a question, i have 4-5 lipos laying around i keep them at 75% charge when im not using them, my 2 turnigy nano-tech 5000 45c's hold a consistant 3.83 across all cells and are never very far out of balance. but i have this one rhino 4s pack for my 2wd slash that reads 3.92 on the first two cells and 4.13 on the last 2 cells(while charging) But time and time again the last 2 cells peak at 4.21v's and the first 2 cells peak at 3.96-98, im wondering if this lipo is going to "kick the bucket" Or possibly give me problems with it in the future. or if anybody has had this problem
RE: Lipo balancing?
Buy a seperate balancer and it should balance out all the cells..
RE: Lipo balancing?
does your charger have a balance charge setting or are you just doing a regular charge?
RE: Lipo balancing?
The state of balance tends to stay for long periods of time. This is why some get away without balancing at all and some get away with a single check every year without any balancing at all and some get away with a once per year balance.
In an ideal case the cells are "in balance" because they started out that way. In your case the cells are "out of balance" and will stay that way until balanced. Balancing the pack (at the full mark) will "fix" it. Otherwise it can be damaged due to 2 cells being overcharged or overdischarged. |
RE: Lipo balancing?
Wouldn't it make it all the easier to balance the cells every time you charge them?
RE: Lipo balancing?
it would not hurt.
RE: Lipo balancing?
I balance my lipos before and after every charge.
RE: Lipo balancing?
Same here, thats why im wondering why my numbers are off,
RE: Lipo balancing?
ORIGINAL: t9dragon I balance my lipos before and after every charge. To see if what I say is true simply start with a normal perfectly balanced pack that is charged. Use it normally or discharge it down to nearly empty. Note any imbalance. Charge the pack back up without balancing it either before or after. The pack should again be perfectly balanced when full. |
RE: Lipo balancing?
ORIGINAL: Redvanmafia Same here, thats why im wondering why my numbers are off, |
