2wd Ruckus help
Hello, I'm new to rc's and just bought my first non toy grade for my 7 year old son and I.
We bought a used 2wd ruckus. My son tripped and bent the antenna so we upgraded to a 2.4 ghz radio. Then LMAO we went ahead and upgraded to 5000mah lipo and a new ecs. We also did a castle brushless. The hobby shop programmed it at 75% power while my son adjusts to the ridiculous jump in speed. After less than 10 minutes of driving, we broke an axle. I'm curious about which axles we should go to now to avoid further down time. What else should we look at to make it more reliable? |
Unfortunately ECX has very little in the way of aftermarket support at this time so you don't really have any options other than stock parts.
You said Axle but by any chance did you mean the plastic drive shaft? If so there is an HD version of those parts available right from ECX. Look for part number ECX232000. Beyond that I have heard of people swapping over Traxxas parts where the stock stuff breaks. |
Thanks for the help. That was the correct part number and the repair was very easy.
Next question is if there is a sway bar kit available. And what can be done to help reduce wheelies |
Originally Posted by john01374
(Post 12087552)
You said Axle but by any chance did you mean the plastic drive shaft? If so there is an HD version of those parts available right from ECX. Look for part number ECX232000. Beyond that I have heard of people swapping over Traxxas parts where the stock stuff breaks. To berretta, you can modify Traxxas VXL shafts to fit. http://www.ultimaterc.com/forums/sho...d.php?t=128675 |
