RCU Forums
-   RC Electric Off-Road Trucks, Buggies, Truggies and more (https://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/)
-   -   Arrma 3S BLX Issue (https://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/11691217-arrma-3s-blx-issue.html)
Kavik Kang 06-19-2021 07:28 PM
Arrma 3S BLX Issue
I am new to this, so I might be doing something wrong because nobody seems to talk about this as a problem.
I have two Arrma cars, a Typhon 3S and Kraton 4S. Both of them have the same transmission. When you put that together to connect the drive shaft a metal piece goes into the slipper clutch/gear (mine is red) and a little plastic piece goes over that, then you put the drive shaft on. At least I think that is right.
That little plastic cover piece between the driveshaft and the metal piece keeps grinding up, and destroying the driveshaft if you don't know it is coming.
Am I putting it together in the wrong order? I've noticed in a lot of videos that a lot of people just don't have that piece on there... is this common, and you don't even need that piece so you just let it go?
Kavik Kang 06-24-2021 05:30 PM
The new one is already beginning to grind up after driving it just 4 times. Nobody else seems to have this problem with Arrma cars, I must be doing something wrong.
First the red metal gear/post thing goes in, then this plastic piece, then you put the driveshaft on? Right?
Does it just work without this plastic piece? Or am I doing something wrong?
I am going to try and just use it without it, I think, and see what happens. I can't keep replacing this little plastic piece every 5 times I use the car.
Rcbasterd 08-11-2021 05:12 PM
Pretty sure u are
I have al the 3s line the kraton 4s fyi kraton is beefer with the meta spur an slipper spring.. But i have had no issues with that. But when i really question myself i first go over the book few times then video i can say im pretty experience with all my vehicle now. But 1 thing i have noticed with typhon my stock bearings are wearing bad. But i did the hobbywing max 10 upgrade an i can promise itll do every bit of 70 only thing heat i gotta get bettet fan on motor. Any suggestions best one? I kno this wasnt really helpful to the post but reasearch always helps me
Kavik Kang 08-12-2021 10:40 AM
The 30x30x10 Protek fans are about exactly twice as powerful as the stock Arrma fans and cost about $18.
