Delphi indy understeers
and its annoying, it killing my handling and i cant have any fun with it like this, anyway could someone guide me through increasing the turn radius? anyone? even a comment would be nice.
RE: Delphi indy understeers
well its cause that car is fair light at the front try puttin weights in the fron or changin th front to toe out
One reason I opted for the Tamiya F201 was because it was 4WD. Isn't the Duratrax F1 version 2WD?
yep it is that the problem with some rear wheel drivers the light end jus makes understeer i now cause i had a delphi an i fitted it with a 6 turn motor couldn't steer
What exactly is your car doing when performing:
A) high speed on throttle turning B) high speed off throttle turning C) low speed on throttle turning D) low speed off throttle turning E) straight line acceleration This information will help diagnose the problem in order to offer potential solutions. Thanks, i8tweety |
What?
you have a PM i8tweety |
On-Throttle refers to when the motor is supplying power to the wheels
Off-Throttle refers to when you are coasting (not applying throttle) |
went to the hhardware store and found these thin pieces of lead, glued em onto the front wing to add wieght and now it is a handling beast, still cant touch my xxx-s though, anyway thanks guys i wouldnt of guessed that the fault comes from the lightwieght of the car.
see ya, Jason |
