Evader BX Pro front wheel bearings/wheel question
I recently ordered and received a pair of stock Evader BX Pro front wheels to mount a different tread tire on. I forgot to order bearings so I went to a local hobby shop and all he had were 3/16" x 3/8" with rubber seals. However, after putting the wheel on the car I noticed I can't snug the lock nut up without binding the wheel.
After taking it off and looking at it, I notice that between the two bearings on my OEM tire, there appears to be a metalic spacer (inside the wheel). On the new tire I just have a big air gap between the bearings. I don't see any spacer on the parts diagram but it sure is on my OEM rim! What's up with this? |
RE: Evader BX Pro front wheel bearings/wheel question
The small aluminum spacer keeps the bearings from binding as all the inner races are bolted tightly and the outers spin freely.
It's number 125 on the parts list and comes with the front axle set number dtxc 6170 |
ORIGINAL: U-dUd The small aluminum spacer keeps the bearings from binding as all the inner races are bolted tightly and the outers spin freely. It's number 125 on the parts list and comes with the front axle set number dtxc 6170 Thanks for the info! Why can't I find a bearing spacer specifically labeled for the BX? The one you reference says ST, though I'm sure it'll work. |
Hmm, my bad. The bx one may be a bit shorter. dtxc 6171
ORIGINAL: U-dUd Hmm, my bad. The bx one may be a bit shorter. dtxc 6171 I guess I'll give them a call tomorrow and complain a little. |
They will probably send you a 12" piece of aluminum tubing,,,, ;)
I made some out of some brass tubing so I have some spares
ORIGINAL: raz54 I made some out of some brass tubing so I have some spares |
