'Lunchbox Streetrod' Build Chronicles
1 Attachment(s)
Ok, I have been obsessed by the Tamiya Lunchbox ever since 1987. When I discovered the Re-Release on the Internet I was sold instantly.
So I bought one and began to mod it. Soon the idea of building a street version grew and some unfinished projects I saw motivated me to get this going. I decided to make a build chronicle for all the Lunchbox enthusiasts out there. First, I bought a pretty cheap RTR 4WD belt-drive chassis and stripped it. It's made by the german manufacturer 'Robbe'. I got the OEM version for the german Hobby-distributor 'Conrad Electronic'. It's go full ball-bearings and has a belt driven full time AWD with ball diffs and super-cheap plastic oil-shocks. The decks are made of aluminium, most of the suspension parts are plastic and don't seem to be very rigid. But there are many aluminium suspension hop-up parts available which I will get my hands on later. But first things first, here's the plain chassis with the cheap stock servo and receiver still mounted: |
RE: 'Lunchbox Streetrod' Build Chronicles
1 Attachment(s)
Here are two closeups of the main diff with motor mount and belt. The aluminium is a nice touch and comes standard:
1 Attachment(s)
First test fit of my Lunchbox body on the chassis, to get the idea.
Pretty mean looking, huh? But there are two problems: 1. The wheelbase of the chassis is about 210mm, 5mm too long for the stock body! 2. The width of the chassis is 160mm and this is also too much for the stock body! [:@] Hmmm.... |
You arn't going to leave the rear raised up like that, are you?
1 Attachment(s)
Problem #1. more obvious:
With the lexan LB body, you can bend the body slightly to maybe cover the wheel!! And w/ the lexan body, you can also cut the wheel arch out your own way to make sure that it clears the wheel.. hee hee!!
No, thats just the long body post in the rear. I plan to let the back sit a little higher than the front though. ORIGINAL: -Brian You arn't going to leave the rear raised up like that, are you? |
Looks cool, a brushless Lunchbox would be cool;) Hint hint:D
Looks alright so far but I think you should do what ever you got to do to get the thing to just look perfect on there and like a low rider I guess you could call it like the body pretty low to the ground. Just my opinion.
I think BL LB has been done before........ [8D] ORIGINAL: rc monkey Looks cool, a brushless Lunchbox would be cool;) Hint hint:D |
1 Attachment(s)
Again, Lunchboxer beat me to it, LOL!
Thats what I was going to say: To solve the two problems, I got the Parma Lexan Lunchbox body on the way, which has flared fenders (body width to be measured by Lunchboxer:D;)). Here's a pic of the lexan shell, note the fenders! ORIGINAL: Lunchboxer With the lexan LB body, you can bend the body slightly to maybe cover the wheel!! And w/ the lexan body, you can also cut the wheel arch out your own way to make sure that it clears the wheel.. hee hee!! |
ORIGINAL: Lunchboxer I think BL LB has been done before........ [8D] ORIGINAL: rc monkey Looks cool, a brushless Lunchbox would be cool;) Hint hint:D |
So you want me to put my MM7700kv in the M-03M so I can claim the title?!?! :D http://image.rcuniverse.com/forum/up...90/Sq47851.jpg ORIGINAL: rc monkey ORIGINAL: Lunchboxer I think BL LB has been done before........ [8D] |
1 Attachment(s)
It will take 3 weeks for the lexan shell to arrive, so in the meantime I thought of something else:
Custom made aluminium rims old-school style. I had them made by [link=http://www.modellbausieghard.de/rc/alufelgen-M-1-10.html]Modellbau Sieghard[/link] in Germany. They are 1/12 scale and similar in size to the Tamiya M-chassis rims. Hopefully, the HPI M-chassis tires will fit! I reduced the offset by 2mm on each rim, so I think the y will fit under the lexan shell. Here are the pics, bling bling! |
ORIGINAL: Lunchboxer So you want me to put my MM7700kv in the M-03M so I can claim the title?!?! :D http://image.rcuniverse.com/forum/up...90/Sq47851.jpg ORIGINAL: rc monkey ORIGINAL: Lunchboxer I think BL LB has been done before........ [8D] |
Nooooo, don't do it! I want to do something before you do, just once! :D BTW: Of course it will get a brushless system! :eek: LOL! ORIGINAL: Lunchboxer So you want me to put my MM7700kv in the M-03M so I can claim the title?!?! :D http://image.rcuniverse.com/forum/up...90/Sq47851.jpg ORIGINAL: rc monkey ORIGINAL: Lunchboxer I think BL LB has been done before........ [8D] |
LOL, Dante's Boxrod will kick some serious tail.. I am not here to one up him!! I look forward to seeing the result for sure!!
In the mean time, I will work on The Frog.. hee hee.. :D By the way, those rims are serious bling!! NICE!! |
Pheww, thank god! I was in shock for a minute there! :D I will keep you posted on the project, hopefully the rims come in tomorrow, haven't seen them in person yet. In the meantime, I will think of a nice paintjob for the body. Hmm... [sm=50_50.gif] ORIGINAL: Lunchboxer LOL, Dante's Boxrod will kick some serious tail.. I am not here to one up him!! I look forward to seeing the result for sure!! In the mean time, I will work on The Frog.. hee hee.. :D By the way, those rims are serious bling!! NICE!! |
I say stick with the original Lunchboxer colors/body. But it's always cool to be way different because I mean your already being different by making an onroad lunchbox. ORIGINAL: Dante77 In the meantime, I will think of a nice paintjob for the body. |
Thanks for the nice comments! My initial plan was to use the stock body, because of the nice look and chrome details. But I would have had to dremel the hell out of it and widen the fenders in some way so I went the path of lowest resistance and ordered the lexan body. We'll see how that fits the chassis. And trust me, the paint-scheme I thought of will look just as good... ORIGINAL: coleholley I say stick with the original Lunchboxer colors/body. But it's always cool to be way different because I mean your already being different by making an onroad lunchbox. ORIGINAL: Dante77 In the meantime, I will think of a nice paintjob for the body. |
Alright I bet it will come out sweet no matter what and I look on this forum and all I see are lunchboxes all over LOL. Makes me really want one but I want a lot of r/c cars so I just have to decide what's next and convince parents to let me get one.
The Lunchbox is a must-have RC! So much fun, but not too stable onroad. That's what I'm going to change! :D |
You meant, "Lunchbox", not "Lunchboxer", right?!?! Sheesh!! :D ORIGINAL: coleholley I say stick with the original Lunchboxer colors/body. But it's always cool to be way different because I mean your already being different by making an onroad lunchbox. |
Ya, don't people do that a lot? (maybe not) But I have seen you correct someone before that said that. LOL
But it still made sense, and you do have the original colors so he got it. LOL |
http://www.e90post.com/forums/images.../bellyroll.gif ORIGINAL: Lunchboxer You meant, "Lunchbox", not "Lunchboxer", right?!?! Sheesh!! :D ORIGINAL: coleholley I say stick with the original Lunchboxer colors/body. But it's always cool to be way different because I mean your already being different by making an onroad lunchbox. |
