16.8v emaxx batteries getting extremely hot
for the past 2 days or so iv been running my new emaxx on 6cells cause i dont have money for 7 cells and every time i take out the batteries they are hotter then the last time is this a problem
RE: 16.8v emaxx batteries getting extremely hot
It depends on how hot. Up to 150 is ok.
i dont have temp gauge but i can tell u it hurt to hold them for more then a few seconds
ORIGINAL: DriftingDragon i dont have temp gauge but i can tell u it hurt to hold them for more then a few seconds |
ok wich would be cheapest to get
keep in mind i als0 just bought the truck |
ORIGINAL: DriftingDragon ok wich would be cheapest to get |
thanks
keep in mind i als0 just bought the truck thanks |
ORIGINAL: guver It depends on how hot. Up to 150 is ok. |
ORIGINAL: DriftingDragon ORIGINAL: guver It depends on how hot. Up to 150 is ok. |
Ya I also have the flashpoint. Couldnt ask for anything better.
they go KAABOOM! LOL i think the solder melts |
o...... ok
ORIGINAL: DriftingDragon o...... ok |
I haven't touched it though once your batteries get to hot they begin to loose their punch and if they get hot enough they will pop. |
ORIGINAL: dirt101 I haven't touched it though |
They are probably closer to 200 then and the problem will be degrading batts (it's already started) Either the truck is using them up too fast for some reason or they are really ge3tting old/junk. Maybe a little of both and if it's the batteries then they should be retired to a slow vehicle, crawler,roto-start, or lightweight stock 1/10 scale car.
the batteries are only bout 6 months old and well i do only get 15 min out of them in my emaxx their 2000mAh
The stock emaxx pulls lots of amps. If those packs are 2000mah then they arent going to last to long in that truck. You need to get some quality batteries. You will think its a new truck if you do.
e-maxx probably should use minimum of 3300's and good quaity cells at that. 15 minutes is great though.
You should put them in your other vehicles and get new ones for the maxx. If you dont they will not last too many more runs like that and you will have to buy some new ones anyway.
Back when I used to race, my packs would be painfull to hold after a race. In my electric planes, I've melted the wrap off the cells. Some guys take the plastic wrap off and use kapton tape because they know that their setup will melt off the wrap. Nimh are pretty tough and they can handle it. I'm speaking mostly of GP cells though. Never tried any of the budget cells you see today. I wouldn't worry too much about a little heat though.
Batteries make all the difference in the world..
sry to bring back this thread but more issuses
my batts are having the shrink wrap on them melt what should i do |
