Hyper St Pro Conversion!!!
I am finally planning my truggy project. After a long time of debating I think i found everything i was looking for. I wanted the truggy itself to be top quality without killing my wallet, so me and a buddy found the Ofna Hyper st Pro kit, $450 new, not bad. Of course I will be using to rcm motor mount, if it works with this model. Once it is rereleased i will be using the monster max for this build. I will need a motor for temporary use untill I purchase one of higher quality, so I looked to unitedhobbies. I found the KD36 series to be just what I was looking for. And as long as I am ordering the motor from unitedhobbies I may as well order the other things i need, like a bettery and servo. I have heard good things about the Zippy-H 4000mah 25-35c 5s battery, so why not give it a try. And I found a decent looking servo for dirt cheap, I have no idea what to expect. All links are below:
Truggy: (Ofna Hyper st pro kit) http://www3.towerhobbies.com/cgi-bin...&I=LXTJH1&P=ML esc: (Castle Creations Monster max) http://www3.towerhobbies.com/cgi-bin...&I=LXUWH2&P=ML Motor: (KD36-74 1900kv) http://www.hobbycity.com/hobbycity/s...idProduct=6678 Battery: (Zippy-H 4000mah 25-35c 5s) https://www.hobbycity.com/hobbycity/...5C_Lipoly_Pack Servo: (SCR 48g / 9.7kg-cm / .12sec Metal Gear Servo) https://www.hobbycity.com/hobbycity/...idProduct=3880 All comments and suggestions are greatly appreciated. Thank you. |
RE: Hyper St Pro Conversion!!!
you gunna want to use 2 batts, if your only goin' 4k's
other than that, it sounds like a good idea rclugnut10 |
For now I'm just going to run one battery. I will see what kind of runtime I get.
Sweet! Can't wait to see it!
I'm just starting my electric truggy project too. I'm doing the following setup:
- TTR ST-1 RTR truggy - Mamba Max ESC - KD36-74-06XL 2800kv motor - Hextronix or Turnigy 3A UBEC - Custom motor mount (since no one makes one for the ST-1) - 12T Mod1 pinion - 12cell NiMH or 2s2p LiPo - No load rpm ~40k Good luck with yours and keep us updated. |
Do you by any chance have that motor already? I am desperate to find out how good these motors are. You build seems very interesting, I will be sure to keep my eye open.
ORIGINAL: bhcvc I'm just starting my electric truggy project too. I'm doing the following setup: - TTR ST-1 RTR truggy - Mamba Max ESC - KD36-74-06XL 2800kv motor - Hextronix or Turnigy 3A UBEC - Custom motor mount (since no one makes one for the ST-1) - 12T Mod1 pinion - 12cell NiMH or 2s2p LiPo - No load rpm ~40k Good luck with yours and keep us updated. |
Why not get the 8ight truggy ?
Think it is lighter and then you will get more speed out of it! |
He has around a $450 budget.
it costs 390 on rcmart.com
ORIGINAL: Ev1er it costs 390 on rcmart.com Awesome project PedeBeater. I am looking forward to see done. I dont know much about conversions, so I cant really give you any advice, but it does sound awesome so far! |
Thanks a lot dude! I actually really have my heart set on the Hyper st pro, even if there are better truggies out there. I will be sure to keep you guys updated and get a lot of pics once I get it.
Thank you, PB |
I am building a st pro myself. Waiting for motor (Neu 1515 1.5D) and esc (Mamba Monster) to come from the states. My next thing to consider is batteries. Do I go 2 X 3s lipo's or a 5s due to my charger being limited to charging 5s?
What run time should I expect from what Mah batteries? |
