e-revo questions
would a spektrum SR3000 reciver work in a e-revo? i am asking because the e-revo uses 2 sevros for the steering. also i am putting in a novak hv maxx 6.5 motor in it. what size pinion should i buy for it? and what other upgrades should i buy for it for hard bashing?
thanks |
RE: e-revo questions
could i get that at tower hobbies?
I'm sure you could... why don't you enter Y harness in towers search box and find out?
As for the HVMax... not sure on the gearing as I have a MMM in my erevo, it would really depend on what you're doing with it. Mostly on road, mostly off road? what kind of batteries? |
i am going to do mostly on road and a little off road. i have 2 6 cell batteries.
this is what i need for the y harness right? http://www3.towerhobbies.com/cgi-bin...&I=LXTSK3&P=ML
ORIGINAL: novakmaxx this is what i need for the y harness right? http://www3.towerhobbies.com/cgi-bin...&I=LXTSK3&P=ML As I don't have the HVmax myself I'm going to leave that for someone else. |
Edit - sorry, I thought this post was in the minis section, ignore my reply.
what is the stock spur gear size on it (i dont have one yet)? also i have read a bit and herd that the suspension is really soft. what is a good set up that is good for big jumps? what rockers should i get?
ORIGINAL: dacaur ORIGINAL: novakmaxx this is what i need for the y harness right? http://www3.towerhobbies.com/cgi-bin...&I=LXTSK3&P=ML or this http://www3.towerhobbies.com/cgi-bin...?&I=LXHZW5&P=7 |
with this http://www3.towerhobbies.com/cgi-bin...?&I=LXHGD4&P=V need a new push rod?
ORIGINAL: Druss ORIGINAL: dacaur ORIGINAL: novakmaxx this is what i need for the y harness right? http://www3.towerhobbies.com/cgi-bin...&I=LXTSK3&P=ML or this http://www3.towerhobbies.com/cgi-bin...?&I=LXHZW5&P=7 |
ORIGINAL: novakmaxx with this http://www3.towerhobbies.com/cgi-bin...?&I=LXHGD4&P=V need a new push rod? |
i am getting the 1/10 scale e-revo.
Oh crap, sorry, I thought this thread was in the mini's section, just ignore my respons's here, my bad.
The stock spur size is 19 tooth although it should be 17 because it runs really hot. As for the pinion for the HV I am not sure but if you are using the stock motors for a bit you might want to put 17 tooth gears in. Hope this helps.
