which lipo battery fits the grasshopper?
RE: which lipo battery fits the grasshopper?
I think just a standard 6 cell fits in there. Im not 100% sure but im close.
if a 6 cell sub c pack fits you can use an intellect 2s 4000mah lipo. its the same size as a 6 cell stick pack.
1 Attachment(s)
Most of the 2S lipos will fit where a 6 cell sub c will fit.
See pic below of a Trinity 6 cell 3700mah nimh pack and a Trakpower 2S 4900mah 25C lipo. |
Oh gosh I did not see that you put LIPO in the thread title. Sorry, in that case I couldn't tell you :D
No idea how good it is, but this one will fit perfect.
http://cgi.ebay.com/HYPERION-SWIFT-R...d=p3286.c0.m14 |
a little off topic, but can the grasshopper handle brushless/lipo power?
I have an elite 4800 Mah, 2S, it fits fine.
Seems to work fine with the stock motor and electronics. This also works fine in Midnight Pumpkin. I suspect an upgrade in motor will eventually require an upgrade in ESC; maybe the next size up brushed motor will work, but brushless is doubtful regards |
ORIGINAL: robwiljas No idea how good it is, but this one will fit perfect. http://cgi.ebay.com/HYPERION-SWIFT-R...d=p3286.c0.m14 |
If you think that's odd, imagine the fact that the novak hv maxx esc comes with dual molex connectors and it's for 1/8 size 4S lipos.
Anyway... most 2S packs will fit if they are designed for car use. Also, while brushless + lipo is usually associated with power you can also use them for less maintenance, better efficiency and longer run times w/ a 17.5t system which I'm sure the grasshopper can handle. |
brushless tamiya's?, my lunchbox's tranny stipped right out with a titan 12t on 7 cells
A good batter y for the grasshopper is one that has the wires that protrude from the side. For example SMC lightning volts, Zippy flightmax hardcase lipos are good as well, plus you can't beat the price on them. I just picked up a Zippy flightmax 4000Mah 30C for $32.18 which is a steal if you ask me. The quality is superb and about 1/4 the price of some of the bigger names. Here's a link to one of the batterey's i own from Hobby K I N G http://www.hobbycity.com/hobbycity/s...000mAh_2S1P_30. It's funny that you ask this question since i just rebuilt mine 2 nights ago. I used my SMC which is the same as the Zippy. Good luck my friend.
The picture of the trakpower next to the 3700 pack is deceptive. The problem is that the grasshopper isn't even designed for cells 3300 size or larger, so most 4200 and such as this won't fit even if they are regular sub c stick packs. I like the ace lipo it is small enough to fit good in all the tamiyas i have found so far.
ORIGINAL: 86waterpumper The picture of the trakpower next to the 3700 pack is deceptive. The problem is that the grasshopper isn't even designed for cells 3300 size or larger, so most 4200 and such as this won't fit even if they are regular sub c stick packs. I like the ace lipo it is small enough to fit good in all the tamiyas i have found so far. |
The Ace Lipo packs fit perfectly in the older re-released model Tamiyas. Just be careful with the balancing plugs they are fragile on those packs I need to replace mine because it snapped. [:'(]
ORIGINAL: Redvanmafia brushless tamiya's?, my lunchbox's tranny stipped right out with a titan 12t on 7 cells the lb has a little bit more weight to push but i have run 9t motors in my hornet with no issues at all. (must have bearings) |
ORIGINAL: Druss ORIGINAL: 86waterpumper The picture of the trakpower next to the 3700 pack is deceptive. The problem is that the grasshopper isn't even designed for cells 3300 size or larger, so most 4200 and such as this won't fit even if they are regular sub c stick packs. I like the ace lipo it is small enough to fit good in all the tamiyas i have found so far. The GH battery slot is tight. I barely fit a 3600nimh IB pack in there, I mean barely. It was made for dinky 1500nicd packs |
ORIGINAL: gman1 A good batter y for the grasshopper is one that has the wires that protrude from the side. For example SMC lightning volts, Zippy flightmax hardcase lipos are good as well, plus you can't beat the price on them. I just picked up a Zippy flightmax 4000Mah 30C for $32.18 which is a steal if you ask me. The quality is superb and about 1/4 the price of some of the bigger names. Here's a link to one of the batterey's i own from Hobby K I N G http://www.hobbycity.com/hobbycity/s...000mAh_2S1P_30. It's funny that you ask this question since i just rebuilt mine 2 nights ago. I used my SMC which is the same as the Zippy. Good luck my friend. i'd be interested to see this thanks! |
1 Attachment(s)
ORIGINAL: 860Crawler ORIGINAL: Druss ORIGINAL: 86waterpumper The picture of the trakpower next to the 3700 pack is deceptive. The problem is that the grasshopper isn't even designed for cells 3300 size or larger, so most 4200 and such as this won't fit even if they are regular sub c stick packs. I like the ace lipo it is small enough to fit good in all the tamiyas i have found so far. The GH battery slot is tight. I barely fit a 3600nimh IB pack in there, I mean barely. It was made for dinky 1500nicd packs |
