xxx bk2 bRUshless motor
hello,
Recently i got back into the hobby and want to know things to look oUt foR when installing a mamba max 5700 kv with esc. any advice is gReat. Thanks! |
RE: xxx bk2 bRUshless motor
It all depends on what car its in and what your set up is gonna be!!<div>
</div> |
What do you mean by setup?What are the risks of ruining the tranny?
<div style="margin: 0in 0in 10pt"><span style="font-size: larger"><span style="font-family: Arial">if the slipper clutch is adjusted properly and the diff is built and adjusted properly then there isn't really a risk worth worrying about.</span></span></div><div style="margin: 0in 0in 10pt"><span style="font-size: larger"><span style="font-family: Arial">if they aren't adjusted properly then keep an eye on the diff gear.it will play connect the dots with the diff ball holes.i learned that one the hard way.worn out diff, lots of power.now iv got a melted 2 peace gear</span></span></div>
