RC Electric On-Road vehicles, race cars and more Discuss electric RC on-road vehicles here. Also discuss brushless motors, speed controllers, brushed motors, etc
Tamiya Baja King Help
Old 12-25-2013, 10:40 PM
Default Tamiya Baja King Upgrade/Re-build Help
Hey Guys
So recently I decided to get out my Baja King and give it a dust down. I received this as a Christmas present years ago. Its pretty scratched up on the bottom and some screw holes are shredded. When using it I notice it veers off to one side. Also I remember getting a full ball bearing kit as well. The body work is pretty damaged as well. Probably should have took more care of it when I first used it. I was wondering what upgrades I can purchase and what I can do to fix it up. I'm thinking about getting a NiMH 5000mAh battery pack and purchasing oil filled dampeners. I've been looking at newer motors but I'm not sure what I should buy. I've heard that that the ESC can overheat as well. My current ESC is the standard Tamiya TEU-101BK.
Any help is appreciated.
Hamish
Old 12-31-2013, 03:19 PM
I've had the Baja King ... Now its a touring car .. Could you take pics on how bad the underside is mate? Also best upgrade ive done its the brushless setup from hobbyking the 11.5T setup with stock gears and 19t pinion and runs cool and super quick! Li-Po is the way forward mate! but you can still use nimh's on brushless but wont give you the ultimate punch and running times will be lower. The steering may be adjustable with the trim on the radio control itself and may be positioned to the side.
Hope that helps
Old 12-31-2013, 09:03 PM
Sure, here's a video of my brothers Baja - http://www.youtube.com/watch?v=0aAbq3AXLh0. Mine is pulled apart right now as I'm cleaning it but here's some pictures - http://s1346.photobucket.com/user/Ha...ing%20Re-build. I've also been talking to someone on http://www.rcgroups.com, also here's my post - http://www.rcgroups.com/forums/showthread.php?t=2063318, you may want to join in on the discussion there, I started talking over there because there was no waiting period for the moderators to check your posts. I'm still a bit sure on the motor but I've decided to get a brushless system.
Here are the links for the stuff I know I'm buying:
Set of oil-filled shocks (http://www.ebay.com.au/itm/110698475...84.m1423.l2649), quick release battery holder (http://www.ebay.com.au/itm/170962455...84.m1423.l2649) and new batteries (http://www.ebay.com.au/itm/181120087...84.m1423.l2649)
Old 12-31-2013, 10:39 PM
phmaximus's Avatar
before buying shocks....
get the HBX upgrade shock towers, that way u can run longer shocks
I haven't used my Baja King for some time.... but here is a little video of it... as u can see its a tat hard to keep straight lol
http://www.youtube.com/watch?v=5xNlVuntoDg
Old 12-31-2013, 10:46 PM
Damn, thats crazy. Could you link me to those shock upgrades please. What brushless system are you running?
Old 01-01-2014, 04:05 AM
phmaximus's Avatar
here are the shock towers....
http://www.ebay.com.au/itm/HBX-RC-Ca...-/170601218626
And it was running a ezrun 35a ESC, 3900kv 380/540 motor on a 3s lipo
Old 01-01-2014, 04:20 AM
phmaximus's Avatar
here ya go, ive dusted the old girl of from retirement...As u can see she is missing a few bits that ive pinched over the years for other cars but these pics should give u an idea of how the towers look and work.
Old 01-01-2014, 03:31 PM
I see you have had to cut some of the wing off, is that necessary? Also I noticed you have, quite a bit of metal and aluminum on there, where did you get those upgrades? And are the any better than the originals? Your tires a huge, did you use it for rock climbing or something? Great build there. You may want to join the conversation at RC Groups as the other guy did.
Old 01-02-2014, 03:09 AM
phmaximus's Avatar
Yes I had to cut some of the wing... wan never a problem as I planed to replace it with a more durable nylon wing
HBX have a newer style body and wing that does not need cutting.
yeah I went a bit nuts on alloy parts... honestly they are just for looks. all from ebay.... I kind of recommend everything apart from the alloy arms...
on my other one converted into a crawler im using the HBX single piece plastic arms
the reason the wheels are so big, is because it exploded a 1/10 buggy tyre from to much RPM and tyre ballooning
they are a spare set of wheels I had from a 1/10 stadium truck... but they are awesome on grass.... now it wheelies and pulls backflips...lol
Old 01-02-2014, 09:31 PM
Awesome, where can you purchase that HBX Body from? What motor are you using? Backflips and wheelies lol, almost a stunt car
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
