RC Electric On-Road vehicles, race cars and more Discuss electric RC on-road vehicles here. Also discuss brushless motors, speed controllers, brushed motors, etc
the OFFICIAL R-40 thread !
Old 04-10-2006, 06:51 AM
  #1076
mikey002
Default RE: the OFFICIAL R-40 thread !
Whats up,
Floyd Bennet Field is a good track. They usually run everyother Sunday.
You need a transsponder. You can go there on Saturdays and practice.
You take the belt parkway to Flatbush ave. south. Right before the bridge you will
see the entrance for Floyd Bennet to the left.
Old 04-18-2006, 03:50 PM
  #1077
D-Nicest
Sab are you going to go to the floyed bennit club race this weekend? also whats up with Remy, I haven't seen him in forever. So far there has already been two official races.
Old 04-18-2006, 05:01 PM
  #1078
nitroracer20
hey guys,
Decided to get my car ready for racing. I rebuilt the whole clutch and cant seem to get the engagement correct at all. Right when I would start the car it would be engaged. So I tried to make the engagement later my tightening the cluitch nut but no dice! I went out the other way for the hell of it and it seemed to get better, but im at about one thread showing on the nut. Whats up with this? Is it b/c Im not running the spring around the clutch shoes? I have ran the car for almost 1 mont w/o the spring amnd it worked fine then?
Thanks again,
Don
Old 04-18-2006, 05:35 PM
  #1079
D-Nicest
Use the spring around the clutch weights at all times because without them your clutch won't engage as hard and you will experience loss in acceleration. To keep the spring from popping out put a drop of C.A. glue at the poit where it joins to gether. Also make sure the clutch bell is able to move up and down from the clutch at least .2 to .5 mm. A good setting for the clutch nut is on one side you see 1 thread and on the other you see 2 threads, it's about, .65 mm if you use a digital caliper. Also check the idle of your engine. Also make sure you put in the the washer behind the clutch adjustment sprind or what ever you call that round metal peice that goes inside the clutch shoe.
Old 04-18-2006, 08:32 PM
  #1080
Saboteur10573
ORIGINAL: D-Nicest
Remy only likes bridgeport. I'd like to race but don't have my Roar and fanatic $$ in as yet - no paypal account. I also gotta pay the tolls and gas isn't cheap anymore. I may go though...not sure as yet.
Old 04-19-2006, 11:03 AM
  #1081
D-Nicest
This weekend there just doing a test and run I dont have my membership or my roar card updated yet and i still have been running. If anything tell remy and his little trash talking mouth that I challenge him to race.[>:]
Old 04-19-2006, 11:24 AM
  #1082
Saboteur10573
HEHE, will do. I'll see if he is willing to go down there as we originally scheduled for bridgeport. Btw I'm on FRRacers as well - I'm Vtech.
Old 04-19-2006, 04:57 PM
  #1083
nitroracer20
yeah....the idle is fine. Im gonna throwthe spring in there and let you guys know if that helps.
Old 04-20-2006, 02:47 AM
  #1084
LiL_D
guys,. i have my first rc too.... and itz r40,. but why is it when i full trotle,. it spin out? help,. thanxz,. you guyzz rock,.
Old 04-20-2006, 11:19 AM
  #1085
D-Nicest
Did you tighten the big set screws behind the rear pivot balls, if so loosen them a bit because theres probably something not free in your suspension set up also, when you say full throttle is it under acceleration or at top end.
Old 04-20-2006, 01:22 PM
  #1086
LiL_D
thanxz,. ow yah one more problem... why is it when i brake,.the engine will stop?
Old 04-20-2006, 02:03 PM
  #1087
D-Nicest
Does your clutch bell spinn freely if not, make sire the clutch adjusment nut is in so that 1 thread shows and then 2 on the other side, also sheck the idle of your engine you may need to raise it or lower it. When you turn on your car do the wheels automatically begin spinning?
Old 04-20-2006, 02:14 PM
  #1088
LiL_D
the wheels is not spinning when i start the engine,. it will spin when i throttle it,. but when i brake,it stop,.
Old 04-20-2006, 04:09 PM
  #1089
D-Nicest
Turn the idle srcew on your engine maybe a quarter of a trurn in, also check your glowplug
Old 04-20-2006, 04:37 PM
  #1090
LiL_D
wats the best glowplug in sirio t3 evo3?
Old 04-20-2006, 09:55 PM
  #1091
D-Nicest
Go ahead and use a sirio 6 or 7, or a novarossi 7, it's sounds like you need an engine tune up for pointers on that go to this website [link=http://www.cefx.net/tips/nitro/tuning/index.php]Josh Cyrul Setup and Tips[/link]
Old 04-21-2006, 12:27 AM
  #1092
LiL_D
thank you so much for the help.... you rock!!!!
Old 04-22-2006, 08:01 PM
  #1093
nitroracer20
o man....
this is a tough clutch to set up. I have tried tons of adjustments to get it to not engage and the only thing I guess it can be is the clutch spring around the shoes. The idle must be just highenough to engage, so it must need the spring to hold it back untill the higher rpms when throttle is applied.
Later
Old 04-22-2006, 08:22 PM
  #1094
D-Nicest
Did you lower the idle?
Old 04-22-2006, 09:53 PM
  #1095
nitroracer20
yeah...i know all the normal stuff to do(i work at my lhs). However, its not everyday that i fix high end 1/10 stuff with centax clutches.
Later
Old 04-23-2006, 12:28 AM
  #1096
3evoman
sup guys, my uncle is going to give me his used r40 with no radio , wat is a good radio to go with in a fairly low price
Old 04-23-2006, 12:57 AM
  #1097
Saboteur10573
How much are you willing to spend? The Airtronics MX3 is about $100, futaba 3PM is about the same price.
Old 04-23-2006, 10:35 AM
  #1098
3evoman
the mx3 looks pretty good ill probly get that, thanks
Old 04-23-2006, 02:10 PM
  #1099
D-Nicest
Hey Nitroracer for pointers on setting that centax go to this link and get to the reading [link=http://www.cefx.net/tips/nitro/clutch/index.php]Cyrul Centax Setup tips[/link]
Old 04-23-2006, 06:59 PM
  #1100
nitroracer20
thanks a million d nicest
