RC Electric On-Road vehicles, race cars and more Discuss electric RC on-road vehicles here. Also discuss brushless motors, speed controllers, brushed motors, etc
the OFFICIAL R-40 thread !
Old 05-15-2006, 02:47 PM
  #1126
churchrvb
My Feedback: (9)
churchrvb's Avatar
Default RE: the OFFICIAL R-40 thread !
im having trouble with steering it feels a lil squirrelly, I adjusted the toe out and that helped a lot, i think its just settings in the radio or like maybe its my epa to much throw?
Old 05-15-2006, 02:48 PM
  #1127
D-Nicest
It's too much too explain so go to this website and get to the reading, follow carefully[link=http://www.cefx.net/tips/nitro/clutch/index.php]Josh Cyrul Centax Clutch Setup Tips[/link]
Old 05-15-2006, 02:50 PM
  #1128
D-Nicest
Make sure the big screws behind the pivot balls arent tight, if they are it creates drag which will cause your steering to not center correctly.
Old 05-15-2006, 04:32 PM
  #1129
Burntt32
yea i dont know too much church was over-exagerating, 2 major things wrong with it that were my mistakes (clutch was too tight and one-way was backwards) and i havnt really had time to fix it which is why he is. anywho just clear up myself. lil_D its an OS .18 tz engine, vantage pipe. and a few other minor things.
Old 05-15-2006, 04:40 PM
  #1130
churchrvb
My Feedback: (9)
churchrvb's Avatar
carbon fiber mid brace for example [>:]
Old 05-15-2006, 05:29 PM
  #1131
LiL_D
guys,. how did you set up ur clutch,. can you guys give me an example on how did you set it up the clutch? like how many spacer will i put on my sirio evo3 on r40,.
Old 05-15-2006, 07:04 PM
  #1132
D-Nicest
There is no specific amount of spacers that will work thats why you should go to the link in my past post. the adj nut should not be tightened all the way, it in fron od it one side a thread should be showing and on another two threads should be showing, read the r40 manual also. I know how to do it but it's too difficult to explain the spacing to you without acutally looking at the clutch myaelf sorry man. use the links.
Old 05-15-2006, 08:10 PM
  #1133
D-Nicest
Hey sab may be going out to floyed or bridgeport on saturday, or sunday
Old 05-15-2006, 09:01 PM
  #1134
Saboteur10573
Sounds good - I may go to prospeed though as it's the opening day.
Old 05-16-2006, 04:44 PM
  #1135
D-Nicest
Hey man if you and Remy are up for Prospeed, I'm there to, thats how I met Remy in the first place. I can't wait to see the new track upstate. I raced remy during practic, and then he cracked under pressure and crashed, won you see me, youd never think I was nice. LOL just Bluffin [:-] Seriously are you going cause I am already planning.
Old 05-16-2006, 09:34 PM
  #1136
Saboteur10573
Yeah he is down and I said I'll go too. It will save me $5 which can go to gas for the xtra mileage. He said he's "loyal" to prospeed. Pretty kewl place and I never been there so it should be really fun.
Old 05-17-2006, 03:17 PM
  #1137
D-Nicest
All right see you there, you should really get back into touring cars man. I'll be running my RRR but i'll have my R40 on the side so if anything like maybe not enough people in 1/8th scale you can use it. Only thing is that the engine can't hold an A-main, the piston sleeve will be done with in atleast 8minuts of hard racetuned running, If you have an engine on the side then be my guest.
Old 05-17-2006, 04:21 PM
  #1138
Saboteur10573
Naw man the way I run my engines they last long. I had the V12, MT12, and now this Nova Top for long times under like race conditions with ease. I'll get back into touring when I make more $$, but for now it's 8th all the way. Besides I'm already set as I have:
setup board
setup gauges
tires
someparts
tire truer with arbor for 8th
So now I just need to stock on plugs, parts, n tires. Sedan I need a whole array of items. I'll sit outta sedan for now as some 8th guys are coming to prospeed.
Old 05-17-2006, 06:22 PM
  #1139
D-Nicest
I was talking about the engine in my r40 it's been through three race season's with oring replacements and one pinched sleeve. The sleeve can't hold up for a whole A-main but will hold up during a heat. Just offering the car to you if you wanted to run touring at prospeed in the case of not enough 1/8th scales showing up.
Old 05-17-2006, 06:56 PM
  #1140
Saboteur10573
YGPM D
Old 05-17-2006, 09:25 PM
  #1141
D-Nicest
On saturday I'm gonna miss work to help out with Floyed Bennit Field. Then hopefully I'll get in some good laps for sunday at Prospeed.
Old 05-19-2006, 07:09 PM
  #1142
mkincy
mkincy's Avatar
I just picked up this R40 setup for $275. droped in a futaba R203HF rx that i had laying around, the 3 port motor in the car fired right up and ran great, the 5 port in the picture i havnt ran yet but appears near new with lots of pinch. what do you guys think, good deal?
Old 05-19-2006, 09:51 PM
  #1143
Saboteur10573
Ohhhh so you bought that! Well it's great for the price indeed.
Old 05-20-2006, 08:28 AM
  #1144
rwong21
Hi Everyone:
I have some stupid doubt.
1.- What differentail gasket I can use? I cannt find in HPI the part number of this pieces. Another option to work.
2.- I would like to know, how I know the difference of the standar shaft and the another one in my motor? I have a MaxPower .12
3.- How I can adjust the anti-squat of this car?
Old 05-20-2006, 09:57 AM
  #1145
Saboteur10573
ORIGINAL: rwong21
Hi Everyone:
The gaskets are on tower hobbies. Click on the R40 car and check for parts
Standard shaft is heavier and made of more components that SG crankshaft. Using SG, the bearings sit on the crankshaft so they spin true. On a std crankshaft the threads can strip and cause wobble which makes gear mesh a pita to do. I'd like to even run SG in my GT...std crank I never really liked. Here's a comparison photo.
For adjusting squat you adjust the droops screws in the rear of the car.
Old 05-20-2006, 07:14 PM
  #1146
rwong21
ORIGINAL: Saboteur10573
ORIGINAL: rwong21
Hi Everyone:
Thk U for the information.
I see in the towerhobbies,but they only sell the gasket togueter with the differential box. I looking if they only sell only the gasket.
In reference of the adjusting squat I need to adjust the droops screws, but I dont sure what is it. Z725 or Z723.
Old 05-20-2006, 08:34 PM
  #1147
Saboteur10573
It would be Z725. That one that comes in contact with the chassis. Look on the underside on the arm.
Old 05-21-2006, 02:04 PM
  #1148
rwong21
Hi,
Who try the Mazada RX-7 body? I would like some opition about it.
Old 05-21-2006, 03:34 PM
  #1149
Saboteur10573
I personally like the Stratus or Caddilac body.
Old 05-21-2006, 03:54 PM
  #1150
mkincy
mkincy's Avatar
well i decided to try out the 5-port motor today (the one pictured in the post above) its a sirio evo2 5-port outlaw. anyway it started with no problem the high needle was closed to about 1/2 turn out it was way too lean to run so everytime i would give throttle it would die, after getting the engine tuned it starts and runs great for about 5 min but then after its good and warm (245 dgrees) or so it becomes very unstable it idles odd like speeds up and slows down and will then die usually when i hit the throttle after leaving a curve,
any ideas? i'm thinking the engine may be worn out as i bought it used and really dont know if its ever been rebuilt
