Lipo Battery Questions....
Yesterday I bought my son(9yrs old) an HPI Sprint 2 Flux with many upgrades and I was wondering about the battery packs for it cus I now have seen many brands and different types.
What is a good Lipo Battery for my HPI Sprint flux?
What is difference from a Lipo and a 6 Cell Battery?
Does Lipo have a longer play time?
Is Lipo better?
which brand do you recomend?
Why do some Lipo batteries dont have the wires?
Can you send me a link from the Tower of a Lipo battery that is already wired to fit my sons car?
Thanks for the help guys!!!
Is Lipo better?
RE: Lipo Battery Questions....
On a Lipo battery what does the big number mean, for example....7.4V 5200 and 7.4V 2600? is bigger the number the longer play time? cus I know the volt is same wich will put out the same power so my guess is that it will last longer with the larger number?
AB, CANADA
I think you need to do a google on lipos, you'll get a lot of information.
The basics are: 7.4v is the voltage. Lipos are based on 3.7v cells so a 7.4v has 2 cells in series. The 5200 is the capacity in mah (milliamp hours), this is how much energy is stored. There is another number called the C rating. The C rating tells you how fast the battery can charge and discharge. In order to find the amps that a battery will discharge just multiply the C rating by the capacity divided by 1000, 20 x 5000 / 1000 = 100amps.
In order to determine which battery you need look at the rating on the motor, then make sure the battery can supply that.
It has to do with the chemistry, not the size. Lead acid batteries used in real cars and trucks can be huge, and they're only 2v per cell. (6 cells in the battery makes it 12V)
I bet Access could explain it.
MA
Inside each battery is an oxidation-reduction reaction, or "redox." Voltage is used to measure the potential of this occurring reaction. So at a molecular level, the potential of this Lithium redox reaction happening is 3.7 volts nominally. Now depending on the concentration of reactions and products in addition to the temperature, the potential, or voltage, is affected. This is why a freshly charged battery (very low levels of product) has a higher voltage and a drained battery (very low level of reactant) has such low voltage.
Good luck!
Good luck!
