New Electronics
I am currently building an on road carpet racer. Wondering if there is anything specific I should be looking for since I have just gotten back into RC and racing after a 16 year hiatus. I am looking for Servo, ESC, and reciever. I currently have a 27T Trinity Epic motor I will be using initially and rubber tires if that has any bearing on the decisions.
ORIGINAL: racerj3
I've the hobbico cs-140 to be a great servo for onroad, and it's only $35. I personally run it in all my onroad stuff.
1 Post
You should be looking at a high speed digital servo. High speed allows crisp control through chicanes. Digital gives you more precise centering to prevent wandering in the straights.
AB, CANADA
Not in most cases. You're not fast enough to see the difference. The only time I've seen a special servo is for helicopter gyros.
For Tx/Rx get something 2.4ghz. There have been a lot of posts about them so lots of information.
WI
Just so you know the CS-140 servo I mentioned is a Digital servo, ball bearings and everything. Speed is good at .13 transit an it has 82oz of torque, which I've found to be more than enough for a car.
http://www3.towerhobbies.com/cgi-bin...&I=LXNRP9&P=ML
ORIGINAL: Druss
Yeah I am still sorting through all the 2.4ghz information.. though I may end up using an old Futaba 27Mhz AM that my dad still has from 16 years ago to start with so I can make sure I get the 2.4 controller I really want instead of just settling for one just to get one.
MA
The CS-140 which I ran on my Cyclone and then on my XXX-CR seems to have a -lot- of play. It's probably responsible for half the slop in my steering. I'm not sure if this is true for all brands' servos, but it's bothering me.
