Why Is There kV ratings and T ratings for BL Motors?
I am sort of confused and a total noob to the BLworld.
Basics of brushed motors of course are more turns = less top end but more torque essential for rock crawling. BLmotors have kV ratings and some have T ratings (I assume short for turns). When a BL motor is says 5600kV as in my Sprint 2 Flux how many turns is that? Also does the less T in a BL motor also equate the same way with brushed motors? i.e. less T = more top end and less torque? And more T = more torque and less top end? Thank You!! |
RE: Why Is There kV ratings and T ratings for BL Motors?
I'm not so sure on T, but the lower kv in bl means more torque. higher kv more rpm and top end.
A good example would be, 1/8th mt or truggy/buggie would be a 2200kv motor or around there, a 1/10th st truck buggy would be around 4600-5700 and higher, and for 1/12th or mini's 10,000 kv. I'm sure someone else will chime in for more info, tho from my basic bl knowledge i think i hit that pretty close to the head. |
plus another thing is that a lower kv motor can generally handle more voltage. If you have a 5700k or higher motor, usually running a 3S lipo or higher is too much for it.
Most companies list the kv ratings of their brushless motors, and some list the # of turns as well. Essentially the # to look at when comparing motors is the kv rating. Brushless motors generally as a rule have less turns than a comparable brushed motor. But the principle stays the same, lower turns = higher rpm on both. Hope this helps!:D |
WillyStylz my man here to save the day...haven't heard from ya in a while bud. Thanks!
No prob! Been on a vacation from RCU the last few months:)
KV rating is describing how many RPM's the motor is going to try and turn per volt at free load. T is the amount of windings the motor has just like the old brushed motors. KV and turns will vary between motor types, manufactures, etc. due to different designs. So a 3300 KV motor will not always be a 17.5 turn or whatever.
An observationI have made, and I could be wrong, seems to me that most if not all sensored motors are rated by turns and unsensored motors are KV rated.
ORIGINAL: OvalRacer99 An observationI have made, and I could be wrong, seems to me that most if not all sensored motors are rated by turns and unsensored motors are KV rated. That is usually the case. I have noticed that as well. |
