Update to 5.5 is.........
I was just messing around in RealFlight 5.0 and it dawned on me the free upgrade to 5.5 might be available.
It is. Just click Additional Options on the launch window and choose Registration/Updates It's pretty big and took awhile to download. I think it was at least 15 minutes. Don't know for sure because I started it and went down to the shop. I test fitted the belly pan on the TF P-40. It won't need any sanding to fit so I came back up. It was just finishing the download and started the install as I sat down. Now there is kewl timing. Haven't had time to look for any new stuff. Wanted to get the word out. If you're on 5.0, it's just like any update version install. |
RE: Update to 5.5 is.........
5.5 also makes new planes available as well as new airfields.
Combined release notes for versions 5.50.010 through 5.50.014 NEW FEATURES: Aero Tow launch method Bungee launch method Multiplayer: Deadringer game Multiplayer: Hardcore Combat game Multiplayer: Streamer Cut (Biplanes) game Timer gadget Sky Grid aids with precision maneuver practice Overhead Gadget shows a top-down view the airport and all aircraft to help you locate the runway and get your bearings in general More realistic wind, turbulence, and thermals. Corresponding menus and settings are simplified Multiplayer: Game limits which allow the host to specify maximum score and time limits for each game (works well with game lists) Multiplayer: Auto-targeting Mode setting for games allows several different selectable targeting behaviors Multiplayer: Simulation Sound Reduction setting controls the volume level when Simulation Sounds are set to Reduced and voice chat is active Multiplayer (Combat games): Point and speed/shield bonuses are awarded based on kills, kill streaks, and kill streak denials Multiplayer (Combat games): The farther a hit strikes from the aircraft center, the less damage it does Multiplayer (Combat games): The player aircraft rocks when hit Multiplayer (Combat games): Damaged aircraft emit a trail of black smoke Damage Sensor electronics component New terrain detail textures Support for an additional terrain texture, called the Modulation Texture, to aid in breaking up detail texture repetition Airport Editor: Added Fade Out Start/End Distance properties to allow objects to fade out based on distance from the camera Heli tail rotor flight failure "Aircraft: Time Since Reset" NavGuide item Console: killEngine command German translation FIXES AND IMPROVEMENTS: New Gadget Tabs appearance Eliminated significant hitching during aircraft contact with water Sim continues executing while menus are active (new setting allows you to select the old behavior). Among other things, this allows games to continue functioning properly in MP while the host is in a menu. Windows DEP settings do not cause RealFlight, the Launcher, or the Installer to crash Swept wing angle of attack calculations are correct Springy landing gear retain their springy behavior after a detachable component breaks off Multiplayer: Aircraft with lots of movable pods don't cause a crash Multiplayer: Canceling the connectivity test in the Join dialog does not cause the sim to hang Multiplayer: Fixed an exploit that allowed other aircraft to be loaded in games Multiplayer: UPnP setup occurs only the first time a join/host is attempted Multiplayer: Host's thermal and turbulence settings are passed to clients Multiplayer: Users you chose to hide remain hidden if they change vehicles Multiplayer: Shield color still matches pilot color if the latter changes during a session Multiplayer: Miscellaneous game balancing tweaks Multiplayer (Combat games): Better sounds Gun components with the same ammo capacity and firing rate will deplete their ammo at the same time Doppler effect is correct when the listener is in motion (such as Chase view) Engine sounds for multiple turbine aircraft do not become muffled randomly Landing gear retract at the correct speed regardless of the switch position when you last reset Aircraft with a nonstandard spawn orientation, like the VFO (EP7), spawn correctly when on top of objects Blur disk for Carbon Fiber Fan heli blades matches their appearance when stationary Rocket require less memory and have less impact on framerate When a projectile strikes an object and stops, its trail and particles stop with it All segments of a streamer remain visible when it hangs vertically View->Show menu is now divided into View->Scenery and View->Effects Aircraft Editor: The prop stops spinning when you select a different visual prop so you can see the new appearance Aircraft Editor: Smoke color is retained when copying and pasting a smoke component Joshua Tree trunk is collidable Console: copyBuffer command captures timestamps if they are currently enabled (see timeStamp command) Menu keyboard shortcuts work properly in fullscreen mode after alt-tabbing away from and back to RealFlight Various particle system optimizations (especially helpful on lower end machines) Miscellaneous other performance optimizations and UI improvements Assorted minor bug fixes not mentioned elsewhere Launcher: Clicking Yes to update when a new version is detected on startup works as expected AIRCRAFT: New airplane: ElectriFly Cirrus SR22 Turbo New airplane: ElectriFly Edge 540 EP New airplane: FlyZone Switch (both Sport and Trainer configurations) New airplane: General Atomics MQ-9 Reaper New airplane: RF-97 Sailplane moved to G5.5 from EP5 New airplane: Russian Thunder New heli: Westland Lynx Expo settings modified on many helis Align T-Rex 500 (EP5): Uses new 425mm Align White Carbon Fiber Blades Dominion 3D (all variants): New canopy Dominion 3D (all variants): Rotor assembly appearance improved, especially for the Flybarless variant Ecureuil (both variants): Fins now break off separately Foiler (both variants): New canopy Griffin Combat VTOL (EP3): Props look and behave correctly P-51 (Combat): Muzzle velocities are consistent across all gun components Jet Ranger: Fixed incorrect appearance after breakapart Sun Dog: New canopy Sun Dog: Fixed incorrect appearance after breakapart Super Sportster: Fixed incorrect appearance after breakapart Thunder Tiger Innovator EXP: Fuselage falls to the ground normally if broken apart in midair V-22 Osprey: Counterclockwise prop looks and behaves correctly AIRPORTS: All airports (G5.5 and Expansion Packs) updated to use new detail textures and modulation textures New airport: Castle HD New airport: Flight School HD Flight School (all variants): New Traffic Control Tower object Soccer Field: Field decal updated with higher resolution version Several runway objects have been improved |
I just installed RF G5 and then updated to G5.5. All seems fine except I can not get the old Realflight interlinkplus to calibrate. It works OK and I can fly. But I keep getting the message that I have not calibrated my controller. I know it works and I can run the older version G3.5 and calibrate the controller there.
Anybody have any ideas? lop - [email protected] |
When you calibrate, move the trims to their extremes.
Sometimes one of the extremes is not seen by the calibration routine, and you cannot "continue" the calibration as a result. |
Just heard from Realflight. There's a bug in version 5.5 that prevents the controller from being calibrated.
Is it a G3 controller?
If so, that's a new problem with one of the more recent releases. Check the KnifeEdge site and apply the beta code. I believe it's already been fixed in the Beta update. ( .22 ) |
I just loaded the RF 5.5 beta and the problem is fixed in this version. I don't know if it's this version or just some planes but upon landing the planes seem to drift way off course with no cross winds. Landings seem to be much "tighter" than with previous versions. With no wind it's still hard to get the plane from "Floating". It's like the gravity disapears. Just my thoughts.
Try recalibrating and make sure you have your physics set to "HIGH".
The default is now an easy or medium setting. |
| All times are GMT -8. The time now is 02:58 PM. |
